Question about Mitsubishi WS-55807 TV
Looses video I can turn on the tv and watch it just fine for about an hour then it looses video, the sound will stay and work just fine. Is something getting hot. can you help.
  • 203 Answers
There are so many thing that can cause this to happen. If you answer some questions we can narrow it down some. 1) when the picture goes black if you hit the menu button on the mitsubishi remote or on the front of the tv itself does the menu show up? 2) After it goes dark how do you get it back? do you turn it off and let it sit for awhile or can you turn it off and then right back on to get a picture? 3) what is the model number? this can be found on the back of the set. If you can answer these questions we can go forward.
Tim Nolan
Posted on Sep 12, 2008
Hi I have a Philips 40PFL3705D/F7 LCD TV. The picture shuts down after a while. Could be 3 weeks, 3 days or 3 hours of watching TV. Still have sound.
Maybe a thermal problem or there is something apart loose even use cold spray, manipulated by slight shaking or tapping components.
Oct 31, 2015 | Philips Televison & Video
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
While watching satellite tv, receiver will work fine for a good while (an hour or more), then you begin hearing what sounds like static in the right front channel, followed shortly after by the receiver...
Sometimes equipment gets too hot and starts glitching. Try an improve cooling and air circulation. Often standing the thing on one end so it's tall will help keep it cool. See if it goes for longer with better cooling.
Oct 29, 2013 | Denon AVR-1911 Receiver
Hd channels are freezing up sound stays on just
Hey there, raeraekub! In order to assist you with this, I need to get a full understanding of the situation, so I'm going to ask you a few questions. First of all, is this issue still happening? If it is, try unplugging the receiver's power cord from the wall for 15 seconds then plugging it back in. If the problem continues, let me know what type of connection you have from the receiver to the TV. What type of TV do you have? With the DVR issue, is the freezing happening in the middle of watching a recording?
Oct 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Tv turns off while watching it stays off a couple
Sharp 60" DLP 1080i , while watching cable, the show blinks off and on. but if we play video games or watch DVD's it works fine. what is wrong?
Jun 23, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Sony KV-35S66 Audio ok but no Video
Is your picture somewhat weak ? This could be a problem with the picture tube . One thing you can try is to turn the screen control up just alittle at a time to see if the picture comes in . Once it does turn off and back on to see it it comes back on again . It might take 10 to 20 seconds but if it does your picture tube is weak . The control is on the flyback transformer it is the bottom control . Or it may be on the crt board on the picture tube . One thing to check once the picture comes is the video input . If you go to this mode and see faint white lines might want to try to turn the control down a little more to see if you can get them out and the picture stays on , if not thats how going to have to watch it . These picture tubes are expensive $500.00 to 700.00 depending on which one you have . One possible other thing if you tell me the picture was a great picture almost like brand new check the horizontal section for a loose connection as this will cause this problem . Don't get shocked and be carefull , Good luck
Mar 14, 2008 | Sony KV-35S26 35" TV
Video channel has diagonal lines
check the connections from your video to your tv, sounds like you have a loose wire,
If not re-tune your tv , it might have lost the tuning a bit , but its probably a loose connection
Feb 28, 2008 | Televison & Video
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
Mitsubishi WS-55807 TV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
