Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
A65 Transducer I have flat bottom boat, Bay Rider to be specific. I get no depth reading from my transducer at any speed other than low idle. The speed and water temp work so I know the transducer is communicating. There is probably interference occuring, but I have moved it several times with no affect. Is there a preferred location/position to mount the transducer???
Jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Posted on Dec 27, 2008
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
My Mark 4 sometimes shows incorrect depths. The transducer has not moved and no problem with electrical. One point it is working fine, the screen then runs multiple vertical lines and the depth chan
Take note if when the vertical lines appear on the screen if the depth numbers begin to flash. If this is the case then the transducer has lost bottom contact and the unit is trying to reacquire bottom contact. If the transducer is parallel to the bottom of the lake while your boat is not moving then, the next time you have it on the trailer, turn your unit on and go listen and or feel the transducer to see if you can hear and or feel the tick or sonar ping. If you can't your transducer may be faulty. If the loss of bottom contact occurs when you are moving it will happen at a certain speed. This is the result of air bubbles passing under the transducer and disrupting the sonar signal causing loss of bottom contact.
Sep 19, 2014 | Lowrance Mark 4 Chartplotter/fishfinder...
Won't work over certain speeds
Think of where the transducer is fitted on your boat . As turbulence is the only problem you need to worry about. It needs too be on the transom but in between the lower 2 chines
Apr 17, 2012 | Eagle Fishmark 320 Portable Fishfinder
When at speed i tend to lose sight of the bottom it becomes very broken. Also the depth reading takes a while to record depth.
What you are experiencing sounds like air bubbles crossing the face of the transducer. If you have a transom mount transducer check the face of the transducer. Make sure that it is clean. Also make sure the front of the transducer is a tiny bit lower than the back. The digital readout on the screen will only happen when you have a strong signal of the bottom.
Jun 28, 2010 | Lowrance Dual Frequency Transducer
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Raymarine a65 transducer 200kh fine 50kh not reading bottom
First do a factory reset and determine that all the setting are correct. You can get this info from the manual. Remember you will loose any saved way points when you do the reset. If that does not sort you out;Remove transducer from transom mount and duck tape it to a broom stick so that the transducer face is facing down. With the boat standing still in calm water and the ducer hooked to the DSM25 push it below the water and see if it see bottom on 50khz.The idea here is to get the ducer in another location to see that it is not getting reflections of the boat. 50Khz is very prone to reflecting of stuff around it. If you still have a problem I would send the ducer and DSM25 unit back under warrant .No need to send A65 back it should not have a problem.
Mar 30, 2009 | Raymarine A65 Combo GPS...
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Log and trip function not registering
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Nov 06, 2007 | Raymarine A65 Combo GPS...
Depth finder problem
The problem is not so much the flat bottom, although they are prone to this problem. The way the sonic waves have to travel through the water is affected by turbulence, especially by air bubbles and cavitation, and by the transducer actually leaving the water, which happens frequently on flat bottomed boats. The best solution to this is to have the unit mounted through the hull so it is completely flush with the hull surface - often they are mounted with a surface flange on the outside of the hull which although thin still causes cavitation around the transducer at higher speeds. about 14 knots will usually interfere with the accuracy of the readings on most hull shapes - forward looking sonars perform usually better. Another thing to check is that the transducer is actually seating right in the housing, if it is not flush with the flange then you have problems - even half a millimetre is too much. check no muppet has painted the transducer with antifouling paint - that never helps, also check if there is a build up of marine growth on or near the transducer - a smooth hull will always keep your depth working until a higher boat speed. if the transducer is growing stuff itself then gently scrape it off - be really careful not to scratch the surface. There are now available non-sonic depth sounders, especially ulf radio signal devices, but I have heard no good reports about them, last i saw they were very expensive and maybe they experience other problems at high speed. there also have been towed devices available that may suit your needs better, although probably a lot of trouble in shallow waters. If you can borrow a waterproof video camera, you could mount it behind (not too close) the transducer, this would be a pain to do, but it may give you an insight into what part of the hull if any is causing the problem (tie the camera to the top of the boat securely in case the mount fails) Hope this helps, sorry but your dealer is not totally wrong :)
Sep 25, 2006 | Lowrance M68C GPS Receiver
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
367 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
