Question about Denon Audio Players & Recorders
I have a Denon DCM-380 5-disc CD player that had some warranty work and was shipped back from another state without the two red shipping screws in place. On opening the shipping carton the player drawer stuck out about one inch from the front panel. Now I can't get the drawer to open or close electronically or manually. Please advise. C. Bradley, Palo Alto, Calif.
    Genius:
  • 1,239 Answers
Hi  check in the link
  1. www.engadgethd.com/2008/07/09/ask-engadget-hd-which-av-receiver-has-the-best-upscaling-chip/   but I would expect the pre-outs to be active all the time. You shouldn't have to enable them. You might want to try redoing the audio configuration on your ps3 - select the HDMI connection then automatic configuration. thank u........................
Posted on Sep 11, 2008
  • 185 Answers
Hai,
You better fix this problem by fixing the screw on the appropriate place,if the problem remains do manual open/close.
Thank You
  • 10,594 Answers
Send it again as you have warranty cover.
  • Shahid Electronics
    Shahid Electronics Sep 11, 2008
    its mechanical timing out problem and its fault of Denon service, so better to send back to get fix it again.
Where is the mp3 plug in for a denon DCM-280
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Denon-DCM-280-CD-Players-review-manual/id/363ci871/t/1-2/
It's capable of playing MP3's right out of the box. See page 18.
Feb 21, 2011 | Denon DCM-280 5-Disc CD Changer
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
67 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
