Question about Dishwashers
We have connected all hoses to dishwasher, tap is on but no water getting through. help
    President:
  • 1,314 Answers
There is a float in the dishwasher take off the bottom panel and make sure the rod coming from the float is engaging the miceo safty switch on the dishwasher let me know and we will go from there
Posted on Sep 11, 2008
I have a DW60CKX1 dishwasher when I select normal wash after about 10 min it flasher E10 what is wrong
Water tap not turned on. Ensure the water is connected
and turned on.
Insufficient water supply
pressure.
Check household water
pressure.
Water inlet hose is crimped
or bent, so no or not enough
water gets to the dishwasher.
Check the water inlet hose and
straighten if needed.
Drain hose is not connected
correctly.
Ensure that the drain hose is
connected in accordance with
the installation instructions.
Aug 02, 2016 | Dishwashers
My ifb dishwasher show F5 and could not complete it's cycle
If your IFB dishwasher is a Neptune DX model, Error code F5 according to the owners manual is "Inadequate water supply"
F5
Inadequate water supply • Make sure the water input tap is totally open and that there is no water cut.
• Close the water input tap, separate the water input hose from the tap and clean the filter at
the connection end of the hose.
• Restart your machine, contact the service if the error resumes.
Oct 01, 2015 | Dishwashers
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
My dishwasher does not fill with water
Turn off the tap.
Pull it out and disconnect the hose from the back of the dishwasher.
Put the machine end of the hose in a bucket, and turn the tap on.
If water gets through the hose, then there may be a faulty circuit board or inlet solenoid. I would be inclined to either get someone else, or take a guess on the solenoid first as it is the cheaper part.
Of course check that the hose is not getting kinked behind the dishwasher.
If no water gets through the hose when not attached to the dishwasher, it may have a faulty water block (anti flood device, usually at the tap end), Replace the hose and you will be all good.
Hope this helps
Adam
May 29, 2013 | Roper 24 in. RUD1000DB Built-in Dishwasher
E1 error on kenwood didhwasher
Gday
As you said, it is not getting water.
E1 is just the machine telling you this.
A couple of easy ones to check:
1. remove the hose where it screws on to the dishwasher, leave the other end connected to the tap (preferably put the machine end in the sink or a bucket as to not make a mess), and turn on the tap. If the water is not getting through the hose, it may have a faulty water block (flood preventer) on it.
2. If there is water getting through the hose, make sure that the hose is not kinking as you push the dishwasher back in to its hole.
3. If there is water getting through the hose and it is not kinked, and you cannot hear any water going into the machine, you may have a faulty inlet solenoid or control board. Might be cheaper to get someone in to fix it. If you were to guess, I would start with the solenoid, as it would be the far cheaper part.
4. If you do hear water rushing in before you get the E1, then the machine does not know that it is getting water. Could be either a faulty pressure switch or the pressure tube that goes to the switch.
Hope this helps
Adam
May 04, 2013 | Dishwashers
Dishwasher is not working, FP DW60CSW1, three of five lights blinking
It is possible you have this error
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Apr 08, 2013 | Fisher and Paykel Dishwashers
Dishwasher not working
try this first is there still water in dishwasher if so your water pump is blocked or failed.
second check your tap connection has it got a flood lock device fitted to hose if so will have to replace hose.if none of these help you may need to replace pcb in extreme cases.
hope this helps.
Jan 07, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
Nothing in instruction about water tap
Yes you need to turn the tap on and leave it on. Otherwise you will burn out the pump.
May 22, 2008 | Danby 22 in. DDW396 Free-standing...
Miele dishwasher g664 12 years old maybe?
if the water drains into a bucket then the blockage will be in the drain spigot under the sink where the drain hose connects.hope this helps.
Mar 14, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
