Question about Canon Office Equipment & Supplies
Installing printhead and cartridges for Pixma MX700
I can't seem either to open to where the cartridges should be installed or find the place where they should be installed.
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
Pixma MX700
See page 82
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Sep 11, 2008
I have an error message B200
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Aug 11, 2017 | Office Equipment & Supplies
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Try removing the print head and placing in in a shallow tray of HOT clean water for a few minutes. Then place it on a pad of paper towels to draw ink and water from the print head. Re-install in your printer and run a deep clean cycle. re-test your printer with a nozzle check. If still no ink showing at all, repeat the process. If no success after that, the print head is probably dying. Printheads can be replaced, but it is cheaper to replace the machine.
Nov 18, 2017 | Canon PIXMA MX700 All-In-One InkJet...
How do you remove the printhead from my canon mx700
You remove the print this pull the scanner up,the carraige return in the middle of printer,then you drag the cart lift up, remove the cartridges....under the cartridge is the print head.If i have been useful please give me a vote :).Thanks
Apr 01, 2011 | Canon PIXMA MX700 All-In-One InkJet...
What does an error 5200 mean?
(1) With the printer turned on, unplug it
(2)Open the top and bring the ink cartridge holder to the middle
(3)Raise the gray bar and remove the print head assembly with the cartridges in it
(4) Lower the gray bar with the head missing and close the top with the head out
(5) Restore the power,wait til the printer wakes up
(6) It will tell you to put in the cartridges
(7) Restore the print head, close the top and the printer should resume working.....
it is a printer head error and some solved it that way ..after you do that it will resume the function and work ..
Jun 01, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon Pixma MX700:one print cartridge not working
The cartridge is only a tank that holds ink. The printhead is the device that you put it into and probably has a blockage in the magenta head. Open the machine so the carriage moves to the center. remove all the cartridges.
TCT How to remove and clean Canon Printhead see the link below. The MX700 may have the locking mechanism at the front of the carriage, so you should move it slightly right and then pull the colour bar forward to release the printhead. carefully remove the printhead. Sit it in a shallow dish/tray of hot water for a few minutes and dry with a paper towel. Put it back in the printer reset the locking bar and cartridges. Try a nozzle check through the tools menu. Yoyu may need to repeat the process if the magenta printhead is badly blocked
Feb 13, 2018 | Canon PIXMA MX700 All-In-One InkJet...
Can I use only black ink cartridge with the MX700? All other colors removed?
Canon printers won't let you do that, all colors have to be installed and not empty, for it to do anything. If you ran with colors removed the printhead would dry and plug and require replacement.
Nov 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
My Printer is saying, some ink tanks are not
If the cartridges are in the correct position, you may have defective cartridges. If you are using after market cartridges, the electronic sensor chip built into the cartridge may be defective. I would remove the cartridges and try using OEM cartridges. You can also try new aftermarket cartridges from a different vendor. This should clear the problem.
Let me know if this does not solve the problem and we can look into other potential solutions.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon pixma mx700 print default
In your print dialogue box should be a setting to tell printer to print black only
Apr 23, 2009 | Canon PIXMA MX700 All-In-One InkJet...
The printer is tell me to ionstall the pint head
Assuming that you have actually read or looked at the installation instructions and been using this printer this error usually means that there's a problem with the printer being able to "sense" or connect to the printhead.
Best way to resolve this is to check the following:
  1. Remove all the cartridges and remove the printhead from the printer
  2. Check the printhead copper contacts (found at the back of the printhead) and remove any ink smears, hair or other foreign material that may be causing connectivity issues
  3. Check that the printhead carriage (the bit that the printhead normally sits in) has no damaged or broken contact pins.. These can be damaged when a printhead is forced into the carriage.
If you've checked and resolved or found none of these to be a visible issue, try turning off the printer, turning it back on and then installing the printhead (without cartridges!) and see if the printer is recognising it..
Then try installing the cartridges carefully and see if that solves the problem.
If not, it's probably either a blown printhead in which case a new printhead can be purchased from Canon or a service center.. or you have damage to the printer that you cannot see and perhaps it's time to replace the printer or take it to a service center.
Hope that helps.
Mar 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannot print Black on anything...
Your printer works with the PGI-5BK cartridge, that are in fact just ink-tanks, the printhead being apart of the tanks, so if the cartridges are not empty, it cannot be because of them. It doesnt matter if you replace the cartridge, the problem is in the printhead.
If the problem occured just a while ago, you should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. OK, now it comes: If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridge are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the printhead on some sheets of tissue.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
Rate the solution if it helped you!
Feb 03, 2008 | Canon MX700 Office All-In-One InkJet...
93 people viewed this question
old marine
old marine
