Question about Dell Inspiron 1200 Notebook
Inspiron 1200 will not run off the a.c. adapter, switches to the battery till dead then shuts down.
  • Dell Master
  • 5,568 Answers
When operating from line power, there is normally two sections in play; the first is the part to which AC is attached, the second is internal to the laptop and manages the DC used by the computer, and presents a controlled charge current to the battery pack.
The external part is pretty easy to check with any kind of multimeter which can be had for well under $20 US and has functions useful for other purposes at home. I think everyone should have one.
If the adaptor is the type with a box that plugs into the AC outlet, it will have a rating stamped or molded into the wall-facing side and will read something like "12 VDC - 1000 mA"  Obviously the values could be different but this will give you a guide if you measure the output of the module at the end of the connection cable. This voltage value can vary by a bunch; one rated at 12 volts may measure 14-15-17 volts since these are normally not regulated and will always measure high when not supplying current. The regulation is done by the internal part, often a separate board.
If you measure a voltage at or above the rating of the module, it is probably OK and that means that the internal regulator is defective. The module (adaptor) can be bought from a variety of sources and ideally, you should get a Dell part or exact replacement since the 'universal' types . . . ain't.  They may be offered with a interchangeable plug and a polarity reversal switch or plug and there is some risk in attaching one to your system unless you have a bit of technical understanding and, that multimeter.  Shop for price though, even on the 'original' Dell part or an exact replacement, price can vary 3:1.
Posted on Sep 11, 2008
How to switch the laptop to ac power source
Connect the mains charging adapter to the laptop and it will automatically run off the mains supply as well as charging the laltop battery.
Apr 08, 2012 | Dell Inspiron 1200 Notebook
What causes a dell inspiron 8600 to shut down and start up on it's own.
1.Memory problem
2.Battery total dead and loose contact of adapter power
check the adapter batttery connections
and next clean and replace memory(Ram)
Sep 17, 2010 | Dell Inspiron 8600 Notebook
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Inspiron 1000 keeps going into hibernation when plugged in
Does your laptop really shut down or is it going into hibernation mode. The way you can check is to enter the control panel and click on the power options. You will find power options for both battery and AC operation. Listed there is the time that the computer will run without any input before it goes into hibernation mode. If you wish to increase that time, just enter a different time. Or you can choose the "never hibernate" option.
See if that works for you. I'm assuming that your computer is just sitting there with no activity when this happens. If this is not the case, then we have to do a bit more troubleshooting.
Jan 20, 2009 | Dell Inspiron 1000 Notebook
No power for laptop Inspiron 1501
try removing the battery and connect the adapter then switch you pc on ,if it works, then you have to change your battery, else you have a bigger problem and need professional, if you are ask for more help.
Dec 02, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1200 no POST
There are two memory slots on this model, but there is no "Onboard" memory. Without the memory that you removed, your laptop will not post. It sounds like a dead motherboard issue to me, especially since you have pretty much torn it down to barebones. Rarely, this can also be caused by the processor but it is less likely. Unfortunately, since you cannot keep it running, there isn't much chance of diagnostics. I hope this helped.
Apr 20, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Dell Inspiron 1200 Notebook Logo
Alun Cox
