Question about Candy CDC266 Dryer
Candy CDC266 Dryer Problem
My Candy CDC266 Dryer works for about 10 mins then switches itself off. if you switch off/on at plug it will restart. I have replaced the on/off switch but this didn,'t help
It might be the high limit going out
Posted on Sep 11, 2008
My candy cdc266 blows my main fusebox as soon as I turn the switch on
Do you have it wired correctly? did it just start to do this?
Look for a wire that is rubbing against metal...look and see if a wire is broke in you heating element....if it is electric heat...
there is obviously a dead short somewhere and you will need to explore til you find it...if you know how to use and ohm meter properly it will help...
Sep 16, 2010 | Candy CDC266 Dryer
I switch the dryer on the light comes on as normal
HI. the filter is fine. Anytime you can hear a buzzing, That is behind the timer module, this will indicate that there is a serious issue concerning the timer mechanism. This device is damaged. The actual timer motor is failing. This will not allow for proper advancement of the cycle selected, in this case. The entire timer control device will need to replaced asap. Once replaced, the unit will operate correctly.
Oct 30, 2009 | Candy CDC266 Dryer
I have a candy cic60 reverse action condenser dryer about six years old.when it is switched on i makes a buzzing noise and nothing happens apart from the buzzing,any ideas
my candy dryer when on the light keeps come on to clean fliter and the water contain dont seem to being filling up with water
Jul 07, 2009 | Candy CDC266 Dryer
Candy cic60 condenser dryer
The drum itself turns on an axle or sprocket. It may need to be oiled. The motor that turns it may be going bad. The windings and bearing could be bad. I assume it is drying O.K.
Feb 04, 2009 | Candy CDC266 Dryer
Candy Easy logic Condenser.
You haven't mentioned emptying the water tray at the bottom if you have you replaced it properly?
Nov 04, 2017 | Candy CDC266 Dryer
Candy cdc266 uk
You have a leaking dryer...? If you mean gas you should have someone qualified look at it.
Jan 16, 2008 | Candy CDC266 Dryer
No heat!!!!!
have same problem /light goes of when in cool cycle.
i think its the printed circuit panel at top of dryer
have ordered one for £9.30 plus postage
hope it works
clean filter out and condenser element
Nov 24, 2007 | Candy CDC266 Dryer
Candy cic60 01 condenser dryer
check the vent line it may be cloged or bent if this is good then possibly the hi temp sensor may be bad ?
Nov 15, 2007 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
284 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
