Question about Sharp Viewcam VL-A10U Camcorder
Eject a tape from my Sharp View Cam
How to I eject a tape that won't eject. I left it in for awhile and when I turn on the camera it says eject tape. When I push the button it won't eject. Is there another way to trigger the eject mechanism so I can remove the tape?
  • mykelsupreme Oct 26, 2008
    tape wont eject
  • mykelsupreme May 11, 2010
    Hi, the problem started a few days ago when i inserted a film into the cameracorder and the message came up requesting me to eject the film but it wont eject. It is a sharp digetal cameracorder model number VL-SD20. Thank you.
Try removing the battery and reinstall it if you haven't all ready tried this
Posted on Dec 26, 2008
Tape will not eject
sir,
If any of your electronics system not using for long period, remember this things( detach the battery or power source , take out cassette or memory card, if the unit use in built chargeable battery, charge it occasionally.
just connect to the power, you don"t power on your camera, the charging light will flicker then push the eject button, remember do not on the power of your cam, hop that this will solve your problem.
Feb 03, 2016 | Video Cameras
Cassette stuck in left side, won't eject
The mechanism transport need work to allow the unit to get back to the stop/Eject cam position. Without that the deck is not going to work. This is usually but not always due to a small rubber belt. That is not all that is needed but the primary reason for that failure.
Jan 14, 2013 | Audio Players & Recorders
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
My camera won't turn on, and I dong know what to do it charges both buttons turn red but it won't eject my disc the screen won't come on or anything
I have a DCR-HC32. I left mine out in the rain. It would not power on. There is a reset button on the side of the eject tape door. I held this in for 5-10 seconds, the camera beeped and I was then able to eject the tape. This was after I put the camera in the freezer over night since I left it out and it got wet. My touch screen doesn't work. I already bought a new camera.
Dec 20, 2010 | Canon DC100 DVD Camcorder
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Wont eject
try taking the two small screws out of the part that reads "do not push this part", this is how i got mine to eject the tape.
Apr 20, 2008 | Sony Handycam CCD-TRV68 Camcorder
Tape want come out
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 03, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Eject
Same problem here with the Samsung D963 (DV cam). I discovered that if you cycle the tape loader without a tape and then load a tape the gremlins leave. At least on mine, the camera doesn't stop for an eject anymore. Hope this helps veryone with this stupid problem. Now if I could just fix the damned battery life....
Jan 15, 2008 | Canon ZR85 Mini DV Digital Camcorder
Do i need a new cam???
You cannot tell if the switch for the eject is broken on the printed circuit boar, or the switch knob may only be internally broke unless you take the camcorder apart. I have seen just the knob break off inside and this know is only a few bucks + the labor, and thats what ia going to cost the most.
Jan 05, 2007 | JVC GRD-350US Mini DV Digital Camcorder
Sharp Viewcam VL-A10U Camcorder Logo
770 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
