Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
How can I fix my whirlpool thin twin washer?
I was told that the timer went out on my washer so I replaced that today and its still having the same problem. It will start to run like normal and then about 3 minutes in the cycle it will stop. I can change the dial to the Rinse cycle and it will again run about 5 minutes and then stop and it won't even go on the Spin cycle. Is there anyone that can help? Please let me know. My email address is starchildjen@hotmail.com
  • 2 more comments
  • Anonymous Mar 08, 2008
    My problem is that the tub seems to be too loose and out of balance no matter how big or small the load.
  • fourparsons Jul 10, 2008
    the washer works fine but the dryer will just stop after a few minutes
  • fchan3173 Nov 16, 2008
    My problem is that the tub is out of balance and the spin cycle doesn't work anymore.
  • Anonymous Feb 24, 2009
    President:
  • 878 Answers
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Posted on Apr 27, 2006
My problem is, the rinse spin cycle does'nt turn on.It does'nt spin and drain the water after a wash.
Posted on Dec 07, 2010
  • spinnaker849 Feb 01, 2011
    i have the same problem....did you get this fixed, and if so, how did you go about fixing it?
Washer stops mid cycle and starts again a few seconds later mostly in the wash cycle is there a problem
Posted on Feb 04, 2009
It keeps filling and running when its in spinn
Posted on Feb 11, 2010
How do I change the switch on my thin twin washer/dryer machine?
Posted on Oct 28, 2008
    President:
  • 3,130 Answers
Also carefully feel the motor housing to see if its overheating as it should get warm to the touch but not HOT HOT.
Dryer quit heating
Posted on Jun 07, 2009
SOURCE:
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Our Whirlpool Thin Twin model#LT7000XTWO will not start when pressing on the start button.Washer works.Could the problem be the starter button or the timer switch? Thanks, Ernie C.
Hello birddog44,
Happy to help you.
You said, Our Whirlpool Thin Twin model#LT7000XTWO will not start when pressing on the start button.Washer works.Could the problem be the starter button or the timer switch?
If the washer works, I can only assume, you are talking about the dryer not starting when you press on the start button.
I believe that it just might be the start button.
Is it a gas or electric dryer?
You have the Whirlpool Thin Twin model#LT7000XTWO
How old is this appliance?
The model # sounds like an older model.
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You,
huuum
Please give me a solved rating for this good advice
Sep 14, 2008 | Dryers
Wash cycle does not start!
if only rinse cycle work. it mean the cycle timer in no good. you need to replace it. i will tell you the cost of it later.
Feb 05, 2008 | Whirlpool LTE5243D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
4,944 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
