Need to know how to hook up to tv - Televison & Video
  • 374 Answers
Most DVD players connect using composite cables also known as RCA cables. Usually you will have a yellow port (video feed) and white port (audio feed) on the dvd player. The red lead is another audio lead to be used with units that provide stereo audio capability. Simply connect one end to the DVD unit and the oother to the TV inputs of the same color. You must use the in ports on the tv not the out ports if so equipped. Then you will have to tune the tv to the proper input that you connected to by using the input button on remote, going into the menu and changing input there, or you may have to channel the tv down past 00 to get to the inputs.
Hope this helps.
HDMI DVD units are the same except the connecting media is different therefor the inputs would be HDMI 1, HDMI 2 or DVI etc.
Posted on Sep 11, 2008
How to hook up vcr and tv using digital adapter
You can hook up the VCR directly to the TV; you don't need to hook up the VCR to the adapter. If you already had the VCR hooked up to the TV, you don't need to change those connections.
Jan 29, 2015 | Televison & Video
Need to know how to hook tv up to prewired home surround system. connections on wall, seakers inceiling
Run the audio output from the tv rca audio output, to any input of receiver and hook your speakers to receiver. You cannot hook up speakers to tv cause its a low level audio output. Needs to be amplified.
Nov 15, 2011 | Televison & Video
I had my playstion 3 hooked up to an hd tv and then i hooked it up to a regular tv..the tv isnt reconizing the playstation at alll..i dont know what to do,
Hook the ps3 back up to the hd tv. From here you need to acces the settings resolution options. Set the resolution to 480 (standard tv). Once set for standard, turn off, disconnect, and set up to non hd tv. Problem solved.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
Ok i need to know how to hook up a dvd player to the tv. I need to know now. Thank you nina
Is there a cable antenna connection on the back?
If so, hook the DVD cable out to the TV cable in.
Put the TV on channel 3 or 4.
There may also be RCA jacks so you can hook the audio and video up direct.
Jul 15, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I don't know how to set the tv to receive all of the channels
Enter the "menu" and select auto program. This will allow the set to search for all available channels. There is also a possibility that when you hooked it up the little wire center conductor in the cable might have been bent over when you hooked it up. Check that first.
Apr 16, 2010 | Sharp 19R-M100 19" TV
I have a dvd/vcr combo and I need to know how to hook it up with a cable box and my new tv
need to know what type of tv, but ususally hook up your cable to your video in on the dvd/vcr and your video out from the vide/dvd to the tv
Nov 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
Nov 14, 2008 | RCA F32450 32" TV
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
