My hp pavilion 9500 laptop is receiveing ac power and all the usual lights come on but it does not appear to be booting up and the mouse is not responding though the blue light is on to show it is active. I have tried turning it off and on a few times using the on off switch. I do not have recovery discs and anyway i do not want to lose all my info. can u help?
  • Anonymous Mar 03, 2009
    power screen.
    HP says no recall, shop says yes recall...
    Problem Solver:
  • 7 Answers
Try disconnecting it from the AC power, take out the battery and put it back in.
Posted on Sep 11, 2008
HP pavilion dv6815nr (6700 series) won't boot after removing and and putting back the cmos battery. How do I troubleshoot this?
You bricked the motherboard. You can;t leave the battery out that long. The capacitor that holds just enough charge to change the battery probably went dead. BIOS is gone.
Sep 01, 2014 | HP Pavilion dv6815nr Notebook
I have a HP Pavilion dv8225nr notebook pc and when I plug the ac adapter into the notebook the battery light keeps blinking and it wont hold a charge. When I keep it plugged in and I turn it on it wont...
It is most likely a bad AC adapter. One way to test it is to remove your battery (I put the steps to do this below) and just plug the laptop in with the battery removed. If it does not power up then your AC adapter is bad. You can buy new batteries online or at your local electronics store. I would advise against buying them from a store though because they are usually much more expensive. I did a quick google search and found some on amazon for a pretty good price.
Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch to the left.
(The front edge of the battery disengages from
the computer.)
c. Lift the front edge of the battery up and swing it back.
d. Remove the battery.
Jun 17, 2011 | HP Pavilion DV8225NR Notebook
Hello. when i plug in my hp dv5220us laptop it sounds like the fans running all cenyer lights on but power button will not turn on. same with battery
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Nov 16, 2009 | HP Pavilion Dv5220us Notebook
My HP pavilion ze1250 powers up, the fan spins, but does nothing.
Is the ac adapter plugged in ? Have you tried to boot it up with removing the battery and using just the ac adapter? Sometimes you are drawing so much current from a bad battery that the computer won't start up at all.
Oct 09, 2009 | HP Pavilion ze1250 Notebook
My BOSS HP tx2000 will not turn on WHILE...
ok Do you hear any soun when your system try to boot?like a beep sound ?
try this remove battert remove the ac adaptor from the noatbookand press and hold the power button for 10 sec and connec the ac adapter not the battery and turn on the noatbook and at the HP logo hit the F 10 key for 2 times and you will be on bios screen hit the F9 ket and restore the setting to default and hit F10 agian to save and exit and allow it to boot it thats work try with battery connected
Sep 16, 2009 | HP Pavilion TX2000Z Notebook
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
Pavilion dv 1000
hook up a extrenal mouse and see if it still does it. If not, get into windows and check your power save options and make sure its not going into standby. Windows defaults to Three minutes on laptops and it may be going into standby.
If it blanks out with all the lights still on, try pressing the power button once and see if it comes on to where it was before. If it does, its going into power save.
These options are in the display settings which you find by right clicking on the desktop and selecting properties in the little box, it will open a box with tabs. click on the screensaver tab and at the bottom it has a button for power options, click it and change settings accordingly, also make sure the screen saver isnt set to come on after like a minute, usually you want it for 5-10 for a laptop and you only want power save options set for when its on battery power.
Also make sure that it doesnt have it set to go into standby when you close the lid.
Mar 30, 2008 | HP Pavilion dv1000 Notebook
Hp 4600 laptop
hmmm...try it with the battery removed only on AC power..
Feb 28, 2008 | HP Pavilion dv6000z Notebook
Start up Probelms HP Pavilion Slimline
Unplug the AC power, remove the battery, wait a full minute and then reinstall AC and battery. See, if you now power up. Most power up problems are related to AC power, DC input jack, motherboard, memory or processor. A lot depends on your comfort level and expertise in how far you should go in self diagnosis and repair. Good Luck.
Sep 08, 2007 | HP Pavilion S7510N (EX255AA#ABA) PC...
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
