Color wheel - Televison & Video
Where i can ged color wheel
Posted on Dec 13, 2008
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
I have a Philips dlp60pl...the picture flickers and the color turn red to green then back to normal color, could this be the bulb.
No.Do the tv pictures colors back ground flashes black and white when this problems happen?Ur tv now make any humming sound or motor noises?Yes,than the tv colors wheel it is the causes and the problems.The tv colors wheel it is dying and starting to be worn out.The tv colors wheel itself it is starting to come out of the spinning motor axis.The tv colors wheel have to be replace to fix this problems.The tv colors wheel sit way back of the tv,must have to take out many mechanical parts before u can even come to the tv colors wheel itself to replace it.If u have no mechanical skills don't tries to replace the tv colors wheel ur self.Hire a tv Tech. to replace the tv colors wheel it is ur best bet.
Sep 24, 2011 | Philips 60PL9200D Projection Televisions
The color goes away, very blue and yellowish. tried to adjust in color menu, but it wont work. sometimes it comes in right for a short time, but then goes back
hi,
You have to check the color wheel of your projector. Every dlp projector have color wheels to provide color. if the rotation of the color wheel is not in corrct RPM this will happen. Also you have to check the color wheel RPM counter sensor. There will be a sensor near the color wheel To count the rotation of the color wheel. First of all you have to remove these two items carefully and clean it well.Then refix it and check. Added the picture of color wheel for your refference.
ok
Jul 27, 2011 | Dell 2400MP DLP Projector
Color wheel flashes multiple colors after operating fine for about 7 minutes. Shuts down on it's own and temp/power light blink amber. No heat exhausting from fan. Problem persists.
hi,
ok
Jul 27, 2011 | Dell 1409X DLP Projector
The picture works but there is a loud roaring noise when you tourn set on
The tv have a colors wheel design into it.The tv colors wheel is dying and spinning off it motor axis.The noises u are hearing are the colors wheel is grinding and hitting it steel hall of it frame box.U have no mechanical skills don't tries to replaced the colors wheel by ur self,because the colors wheel sit way back of many mechanical parts of the tv must take out before even can come to the colors wheel itself to replaced the colors wheel itself.Hire a tv tech to do the job to change the tv colors wheel.If u have no mechanical skills to take out and putting it back of tv colors wheel itself,because u will regret it,if u do it ur self and putting in the colors wheel in the wrong way to the tv itself.
Apr 14, 2011 | Samsung HLN5065W 50" Rear Projection...
After watching tv for a while I loose the color??
This tv have a colors wheel.The colors wheel effects is dying or dead are make loud squiling noises,motors noises and loose colors and flashes or flashes black&white with the picture.The colors wheel,must be replaced to solved this problems.The colors wheel is pretty hard to replace,because u require take many machanical parts out.Before u can even replaced the colors wheel itself.So hire the tv Tech. to replaced the colors wheel.
Nov 24, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Noise from color wheel
for any friends who is looking for optoma projector color wheel, DV10, HD20, HD70, HD70i, etc, please freely contact me, i'm a professional wholesaler and net retailer on projector spare parts, most of brand and all series, lens, color wheel, bulb and remote.
Jack
flying200809@gmail.com
Nov 16, 2007 | Dell 2200MP Multimedia Projector
Televison & Video Logo
359 people viewed this question
Top Televison & Video Experts
