Panasonic model TH-42PW4 manufactured 2001. TV cuts out and goes into stand-by. Sometimes only bottom half of display works. Can hit on button and it will come back on, not dead yet. Dennis
  • 3 more comments
  • TH42PW Sep 11, 2008
    Power button is not my problem. Can you get me more specific information on which parts to purchase to fix this. If power supply what part number if you know this. If some board what board? Could it be the Y-Stain board? So am I asking to specific of questions?
    This is not a projection tv. I have unplugged the tv in the recent past attempting a reset of some sort. This problem has continued for about 3 weeks. I am prepared to replace components but would like direction on which one to replace. Would like to get parts from ShopJimmy.com if possible. So far I have yet to get to one of you real technical tv pro's. No slam intended. This old of a TV could cost me a few hundred or more if I take it in to be repaired. Any other ideas? Please don't give up on my problem.
    Dennis
    With responses like this my TV will never get fixed. This is not working.
  • TH42PW Sep 12, 2008
    TV getting worse now attempting to power it up results in going into stand-by. Green power light flashs red. Sometimes I can get a picture after several attempts. It is broken.
    No great detail, the TV is dead.
  • 10,594 Answers
Please just see Jaime867's answer.
Bye.
Posted on Sep 12, 2008
    Master:
  • 726 Answers
It sounds a bit like power supply to me but with the darkeness can mean the pic tube has run on ya or even a resistor or capacitor
Posted on Sep 11, 2008
  • 2,326 Answers
I would suggest to measure the voltages from the power supply to the Y and X sustainer boards, the voltages should be written on the boards next to the connectors. If the voltages appear normal, there could be a loose contact in one of the flex wires that connect the Y or X boards to the main board.
  • 185 Answers
I saw this one when the new models came out in Feb. To get around this with any IR remote, you need to...
Stack the discrete "on" code either 4 or 5 times (verify number on-site) - no delays - to get the panel to power all the way up.
This has fixed 100% percent of our systems that displayed this problem.
Hope it works for you.
You can download the latest Plasma tools here:
(http://www.pixelmagicsystems.com/support/downloads/firmware/index.htm)
Thank You
    Genius:
  • 1,239 Answers
Hi sir
there may be problem in cathode ray tube or diplay settings follow this...Opinions differ on exactly how to prevent noticeable burn-in. This seems to be the common wisdom:
  1. Turn down the white level (contrast/picture). Most displays ship WAY too bright. See the calibration section for more details.
  2. Don't leave static images on the screen for a long time. Be careful of network logos. If you watch only one network with a high-contrast logo for hours on end, beware.
  3. Turn down the white level.
  4. Don't watch a lot of 4:3 material. If you do, zoom or stretch the picture to fill the screen. For those few shows which you simply must watch in their original aspect ratio, use gray side bars. But don't be too reliant on those side bars -- even gray side bars eventually cause burn-in. That said, the occasional 4:3 show, even with black side bars, shouldn't cause undue problems.
  5. TURN DOWN THE WHITE LEVEL.
  6. Use an orbiter. Opinion differs on how effective this really is. It seems to make the burn-in edges a bit less sharp and conspicuous, though.
  7. TURN DOWN THE WHITE LEVEL! (Get the idea?)
  8. Get in the habit of using a screen saver. Using the White Bar Scroll for a few minutes at the end of each day should go a long way toward countering the effects of side bars, network logos, and whatever other less-than-optimal things you put on your screen.
  9. thanks;;;;;;;;;;;;rate itIn a word, don't. See the service menu warning above. If you're bound and determined to make use of the service menu, buy the service manual. It contains more than enough informa......
  • 19,396 Answers
Try unplugging power for fifteen or twenty minutes, see if this basic reset can fix the problem.
If you have a dark shadow on the upper part of the screen it is probably one of the mirror in the light tunnel that is out of place.
If light tunnel is ok then there is something in the middle of the light beam, this talking about a projection TV.
On other models is just a faulty component.
The TV must be taken apart and inspected internally to fix this problem.
  • Ginko
    Ginko Sep 11, 2008
    Hi, sorry, my first answer was for an LDP TV, things are much different on a plasma.
    The black half screen of death is a common problem on plasma, and there can be more then one fault causing same effect (see here:Half Black Screen - AVS Forum)
    First inspect the aireation intakes at the back of the TV, if you find dust over there , clean it with a hoover, bad ventilation and overheating can be a cause for this problem.
    Try gently wacking the TV on the sides, if this affect the problem, then it is probably a bad connection (t Ysus board likely).
    If the above did not work it is likely to be the Ysus or Zsus board. On Panasonic this boards are called just PC board, you will need the service manual to identify the right part.
    Here you can buy the service manual and all parts for your TV.
    Regards
  • Ginko
    Ginko Sep 11, 2008
    Try first the tricks above, see if by chance you can fix it.
    If you does not fix it you can call the phone number at the end of the user manual to contact PANA. If
    the unit is still under guaranty the job can be done for free.
    If guaranty is expired you should be able to buy an extension that will
    be less that the repair fee and will cover you for one year or two.
    Sergeant:
  • 241 Answers
Well Dennis I do not want to discourage you , But it is a problem with the power module or the the board
just for kicks have you seen if the remote Power Button is sticking or the TV
I know this sounds crazy but if the remote is sticking it will send an IR signal
to shut off/stand by
Thank You
jayson
  • 2 more comments
  • Jayson Brollini
    Jayson Brollini Sep 11, 2008
    Ok here is the price list and All the parts that I had mentioned
    www.electronica-usa.com/Merchant2/merchant.mvc?
  • Jayson Brollini
  • Jayson Brollini
    I am still here Your tv model that you supplied me is coming up as a Projection
    Can you please verify the Model Please
    I am very sorry
  • Jayson Brollini
    Jayson Brollini Sep 12, 2008
    This is what I am going to suggest and Please we understand your frustration
    it is very difficult to direct you into the exact problem without testing the board or
    the other components.. If I suggest to purchase a new power module for your TV
    and that was not the Fix... I wasted your time and Money. A TV Repair specialist will
    charge 25 to 50 dollars to look at it and tell you the part that needs to be replaced.
    This would give you the best info so if you decide to fix this yourself you will have the part that
    needs to replaced and then go online to the dealer and order it. Most of this parts that have been mentioned to you can be fixed/installed by a novice.. With online instructions you should feel very confident. But you can make a choice as what will be the cheapest route for you.
    So Please understand somethings can be fixed online but for us to give you the exact parts is extremely difficult... When you bring the TV in let him know that it is Flashing(that is a code) Please understand..
    Thank You
    Jayson
    Please rate your FixYa experts solution.
What does D516 control for the 42 Panasonic TH-42PW4 its been damaged and how to replace D516
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 23, 2016 | Panasonic Televison & Video
I have a panasonic plasma tc-p50s1 half of the screen is black bottom half
My best guess would be that your SD board is bad. On this model think the part number is TXNSD1EDUU.
Apr 02, 2014 | Panasonic Viera TH-50PZ800U Plasma TV
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Nov 30, 2012 | Televison & Video
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Service menu codes
Panasonic TH-42PZ80U Enter Service Mode InstructionsWith TV on, press and hold the volume down button on the front of the TV, and press info three times on the remote. Select Category Instructions1 and 2 Change Data Instructionsvolume up and down Exit Service Mode Instructionspower down Menu Categorywb adj Menu Itemsrgb cut rgb drive all cut all drive -->do not use these unless you need to match ywo displays side by side.
Apr 16, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Plasma TV model TH42PD60U Shuts off power led flashes 7x
There is a software upgrade to address this particular problem. Contact Panasonic to see if the upgrade can be provided to you free of charge.
Oct 30, 2008 | Panasonic TH-42PD60U Television
Televison & Video Logo
479 people viewed this question
Top Televison & Video Experts
