Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Chemical odor We have a sweet chemical odor in our boat cabin, it leaves a sweet taste in your mouth. I cannot find the source. The fridge does not work. You can smell the odor stronger when the A/C is turned on or when the boat is closed up with the A/C off. Help????
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi serena38,
I'm Harvey the Master Plumber.
Your question is: You have a sweet chemical odor in our boat cabin, it leaves a sweet taste in your mouth. You cannot find the source. The fridge does not work. You can smell the odor stronger when the A/C is turned on or when the boat is closed up with the A/C off. Help????
Great, I live on a boat! I can think of two reasons for this. The first and most likly is electrical. Look carefully at the components especially the capaciter, it's on or near the motor. If it is leaking or out gassing, replace it. Wire corrosion can cause a wire to slowly give off fumes. These kinds of problems are common on a boat so look very carefully i.e. testing meter is helpfull here. I've already expirienced this and it sure was hard to find. Less likely is a freon leak. You won't smell the freon itself but if the oil is a little burnt, that can be smelly indeed. You will need a special leak detector for that. Anyway my money is on the electrical.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
There is and odor that permeates the ice, freezer, and fridge. It makes the ice taste funny.
This could be because of other stuff in the fridge. Meat usually gives a weird odor and taste when its in the fridge with something else.
Mar 26, 2016 | Refrigerators
Bad tasting ice/water/food
Have you put a few boxes of baking soda in the fridge to absorb the pungent odors? Do that.
Jul 07, 2017 | Kenmore Side by Side Refrigerator
Kenmore fridge with a strong chemical taste in water and ice
Every time you replace a water filter you want to purge about 3-4 gallons. Or maybe the filter was bad.
Dec 31, 2012 | Refrigerators
Chemical smell in frig permeating food taste. Is it dangerous
First remove all the food and produce and thoroughly clean the fridge with disinfecting wipes, then put a couple of boxes of Arm And Hammer Baking soda in the fridge to absorb the odors. And no it is not dangerous in my opinion. I have smelled fridge odors that would gag a maget
Apr 25, 2017 | Refrigerators
New problems have surfaced that I think may be related. It started where my AC was pushing hot air out. Now I have a funny odor which started out kinda fishy only when I turn on the heat, accelerate to...
OK. ONLY TWO POSSIBLE THINGS WOULD DO THAT ONE IS A/C FREON FROM THE EVAPORATOR CORE , THE OTHER IS ENGINE COOLANT LEAK FROM HEATER CORE. BOTH ARE EXPENSIVE TO REPAIR. THE BEST I CAN DO IS TO HELP YOU DIAGNOSE THE SOURCE, SO IF YOU CAN SMELL IT, THEN I WILL ASK YOU TO TASTE IT. TASTE WITH YOUR PALETTE, WHEN YOU CAN PICK UP THE SMELL, THEN SLOWLY DRAW SOME AIR THROUGH YOUR MOUTH, AND I MEAN SLOWLY. IF THE TASTE IS SWEET TO YOU THEN IT IS ENGINE COOLANT. IF IT IS PUNGY OR IRRITANT, THEN IT IS FREON. GOOD LUCK AND PLEASE LET ME KNOW WHAT YOU FIND.
Sep 07, 2011 | Saturn SL1 Cars & Trucks
Fridge has chemical smell
The smells are being pulled in through the air intake from the fridge from the chemicals they used on the floor. As the coating cures, the odor will end. As for the damage to your food and drinks? I would assume if the food tastes like the chemicals, I would avoid eatting them if you do not like the taste )
Apr 06, 2009 | Hotpoint HSS25GFP Side by Side...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
Oct 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
198 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
