How do I connect an old VCR, with input/output jacks, to my Dell Dimension 8400?
  • 70 Answers
Buy a rf modulator from radio shack best buy or anywhere with electronics
Posted on Sep 21, 2008
Where is my physical micropone in a dell 8400? speaker
There is no physical mic on the system. You will need to purchase a mic and plug into the port on the back of the desktop in the pink port.
This jack is used to attach a standard personal computer microphone. Connect the audio cable from the microphone to the microphone jack.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 18, 2013 | Dell Dimension 8400 PC Desktop
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
Microphone jack
Green is input audio and I believe the light blue is the mic jack input the best way to find out is go to the sound manager menu and open the mic to see of you can adjust mic if not you are in the wrong input keep plugging it in to each jack until one of them works you will see movement. Here is a link to a manual for your brand and model Click Here
Apr 22, 2012 | Dell Dimension 8400 PC Desktop
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
My 6 year old Dell Dimension 8400 quit working completely.
Depending on the symptoms, you may have different faults.
Flashing Amber power LED, normally power supply
AAGG Diag LEDs normally bad RAM
Solid Amber Power LED, bad motherboard or Expansion card connected to it.
If you need a motherboard a Precision Workstation 370 motherboard is essentially the same and is available, (8400 motherboards are scarce)
Feb 05, 2011 | Dell Dimension 8400 PC Desktop
Where to connect external speakers to dell dimensions 8400
There should be a light green female 1/8" jack on the back panel. Some PC's also have one on the front.
Sep 20, 2010 | Dell Dimension 8400 PC Desktop
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
Right speaker on dell 8400 will not work. what is wrong?
Reseat the speaker connection to the sound card (duplex jack, if not fully seated will give only left channel)
May 03, 2010 | Dell Dimension 8400 PC Desktop
How do you tape on vcr from a vcr?
The 'quick and dirty' way is to connect the VCR playing the tape via the RF OUTPUT coaxial connector to the RF (sometimes ANTENNA) connector on the recording VCR with it set to channel three or four. BOTH units must be set to the SAME channel. The better way is to use the RCA jacks and all but the very oldest should have a yellow jack (Video) output connected to the other unit's (yellow) video input and for sound, the output white jack connected to the white input jack (left channel) and the red output jack would go to the red input jack on the recording unit. This latter method yields a cleaner signal than the first method.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
