Home | Panasonic | RX-D11 Cassette/CD Boombox | CD player not working
Panasonic RX-D11 Cassette/CD Boombox
Problem for Panasonic RX-D11 Cassette/CD Boombox
By Jalila on Apr 26, 2006
CDs won't turn on platter and don't read. I don't have a screw driver long enough to take apart the unit. I figure there's probably a little elastic that's popped off under the platter which could be replaced. Thanks for any assistance.
Clarification Request
Posted by phospheratu on Apr 04, 2008
How are you supposed to use a lens cleaning disc if it won't read discs?
Same Problem
Apr 09, 2009
-   I had the same problem; my CD player on my Aiwa CSD-TD49 would spin a bit, but the counter stayed at 0:00 with no sound. Thanks STAT's solution I was able to fix the problem. Thank you STAT..... -   Guest
Nov 06, 2008
-   compact laser lens with rx -es25
-   Guest
Oct 05, 2008
-   CD's will not play, seems to be turning disc display reads"no or nd", cannot get it to play. Radio and cassette player working fine.-   jkoniar
Oct 05, 2008
-   CD's won't play, displays reads "nd" radio and cassette player work fine,
How do we get cd's to play again?-   Guest
Sep 24, 2008
-   it work read any disk-   kralles
Best Solution
posted on Jul 18, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Could also be that the lid/catch is not closing properly, or warn/ The motor does not spin un;ess the lid is secured properly
Solution #2
posted on Apr 27, 2006
Helpful)
techman
Rank: Guru  Panasonic Expert
Rating: 86%, 7624 votes
NO NO NO NO NO NO dont be sticking a screw driver where you dont know where its going!!!! Theres no belt under the turntable as its a direct drive motor. It the platter dosent turn then that means that the laser is not focusing on the disc. This could a combination of five differant things. First is a simple one as the lens may need cleaning. Try first by using a good lens cleaning disc. Second make sure the slider that the lens is attached to is all the way back to the platter as sometimes there is a small belt that drives the slider assy via a worm gear and that belt goes bad alot as the worm gear i've seen get gunked up with air and dirt. Third is the platter its self . It may have slipped down to close to the lens and it wont focus. Forth could be the motor drive curcuit is defective . Coulkd be a bad motor control ic or the b+ going to the curcuit. and finally but not least could be a bad laser assy. If this is bad you might as well buy a new unit unless you can install one your self but be warned if you do you will need to alighn the new PU assy for tracking and focus gains as well as rf azmuth and laser power. Good luck I hope this put a little lite on the subject for ya.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Nov 13, 2006
Somewhat Helpful)
STAT
Rank: Apprentice
Rating: 68%, 5 votes
I fixed the CD player on my Aiwa CSD-TD49!
The CD would spin a bit, but the counter stayed at 0:00 with no sound.
Open the unit carefully by removing the six screws on the back, and one on the bottom (all have arrows pointing to them.) There is an antenna wire on the left side, and some more on the right side. You should be able to pull the rear section back enough to shift it to the left.
Look at the unit from the rear left side. There is a small white adjustable potentiometer or variable resistor. Mine started out in an almost horizontal position, and through turning it clockwise almost a quarter turn, fixed the CD player. I can't tell you exactly what this did, but it worked. It was a little hard to put the unit back together, but just be gentle and patient, and you'll get it back into one piece.
Hope this helps!
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Dec 05, 2008
Somewhat Helpful)
gmsteinberg
Rank: Apprentice
Rating: 75%, 1 votes
December 5, 2008
The Sony CD player (CFD-S26) won't spin and therefore it doesn't play. Any suggestions or help would be appreciated.
Thank you!
Was this helpful?
Yes
No
Solution #5
posted on Aug 01, 2008
Not Rated)
todd608
Rank: Apprentice
Rating: 0%, 0 votes
At first I was using a CD-RW, I tried a different CD-R and it worked...apparently this is an older player and 48x CD's work.
Was this helpful?
Yes
No
Solution #6
posted on Mar 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
way to go guy it makes a lot of sense
Solution #7
posted on Mar 11, 2008
Not Rated)
mangkukulam
Rank: Apprentice
Rating: 0%, 0 votes
can u give no# parts of sound ampli
Was this helpful?
Yes
No
Popular Solutions for Panasonic RX-D11 Cassette/CD
Questions and Unsolved Problems for Panasonic RX-D11 Cassette/CD
Do you recommend Panasonic RX-D11 Cassette/CD Boombox?
Answer
Answer
The CD will not rotate at all, and it only plays one station on the radio. I would like to know how... (More)
Answer
the cd spins, light blinks, but does not open. plz help.
Answer
I have a Logik F3 mini hi fi system - the radio works but when I put in a CD is reads it but then... (More)
Answer
SOS.........SOS.SOS...........CD PLAYER OPTIMUS DOESNT SPIN,.........RADIO,CASSETTE R FINE ,I... (More)
Answer
I have a 10 year old Panasonic Portable stereo and have left it unplugged for about three weeks. It... (More)
10 Other Users Have The Same Problem - Continued
Comment by nads-putty, posted on Sep 19, 2008
when i put cd on the screen says no disc and doesnt play. tried putting disc cleaner on but even that doesnt work
Comment by tsunamijavip, posted on Jun 06, 2008
My cd Player dont work. 1 year after buy it, dont read CD
Comment by LACLAVE, posted on May 20, 2008
The cd problem started as a intermittent problem first it would spin but not read any of the disc that i would play.Then it stopped working all together. I carefully took it apart and visually inspected it. I don"t know what part is defective? How costly is it to replace the cd component of this radio? Their were 4 screws holding the whole circuit board assembly in place with a nine pin wiring harness plug into it. If i could find the whole assembly as i took it off i will replace it my self. or maybe someone else might have a suggestion other than having to pay $50.00 and postage to send it out for repair!! HELP!
Comment by Guest, posted on May 18, 2008
I have split the speakers and attached them to my speakers on to my boat dock down on the lake. Will that make a big difference? I can hear the cd's changing even shows on the front of the unit. But no sound. Do you have any suggestions? Thanking you in advance for all of your support. I do not know the number of my unit. Where would I find the number on my unit?
I remain Mr. T. Jewell
Jewellhoward@aol.com
Comment by Guest, posted on May 13, 2008
funtion buttion not working
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic RX-D11 Cassette/CD...:
Top Boombox Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Boombox Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
