Question about SanDisk Sansa m230 MP3 Player
How do u free 8MB on a sansa m230
Well i tried to sync some music on my sansa m230 and now when i turn it on is says i need to free 8MB.....so i dont know how to do it and now i cant listen to music...
  • 3 more comments
  • pickle_nic Sep 18, 2008
    i need to free space from my sansa 260, too. i have a completely empty player and it still says i need to free space, but i can't get music to write to it. i am also not able to find a rhapsody player compatible for macs. can someone help? thanks!
  • Anonymous Nov 26, 2008
    i jvhbvk ygg
  • theballer077 Dec 02, 2008
    when i cut it on its sayin i need free space
  • mcabral21 Dec 24, 2008
    my sansa is askin me to free some space. but hours earlier itwas ok>? does any one know whats going on?
  • trailorjay Dec 24, 2008
    how do free 8mb on a sansa m230 please notify me plllllllllllllllllease soon
How do i free 8gb from my mp3 sansam230
Posted on Sep 19, 2008
SOURCE:
Help
To free space on it all you have to do is delete a few songs.
To delete songs:
Plug it into your computer, launch Windows Media Player and click the "Sync" tab. A list of songs in the player will appear in folders on the right side of the screen. Expand the folder if you need to, then right-click on each song you want to remove from the player and click "Remove From Device". Hope this helps you
Sep 15, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
Not Enough Room For Music DB.. Please Free 8MB? ...HELP
Get the firmware upgrade from SanDisk's website:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 14, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa
try plugging it into the computer and viewing at as a hard drive, then you will probably be able to see everything on the player
Mar 19, 2008 | SanDisk Sansa m240 MP3 Player
Help with getting old music off sansa m230
Try going to "My Computer" clicking on Sansa, opening the music folder, and deleting the songs from there.
Mar 10, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
Not enough space for music db
Your device has too much music on it.
You need at least 8MB free in order for it to build the "database".
Connect the device to your computer, delete 10 songs, then re-start the player and you should be back to normal.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa m230 MP3 Player
No files
The device needs at least 8MB to build the Music DB (database or GUI). You need to manually delete some files from the device. You will need to connect it to the PC and open it in My Computer>Device Name>Music Folder. Delete a few songs, disconnect and restart the device. You can add to the question if you need more assistance. Best of Luck.
Sep 30, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
131 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
