Question about Pioneer Audio Players & Recorders
My pioneer SX-2700 home receiver is makeing a ticking noise when i turn it up to a quarter volume
SOURCE: Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Posted on Dec 07, 2008
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
SOURCE: Pioneer Stero Receiver model SX-3700-
It sounds like your volume control pot has dust in it.You need to remove your cover from the receiver,spray pure denatured alcohol in the small openings in the back of you volume control dial and turn the knob all the way up and down several times and then blow low compressed air threw the same small openings while rotating your dial.That should fix your problem.Be sure you unplug your receiver before performing this procedure.
Posted on Feb 20, 2009
  • 4234 Answers
SOURCE: Can't find part needed.(Pioneer SX 1250 volume control part # ACV-169. Is there a replacement
Your only recourse at this time is to check with local servicers that may have one around in their old stock. Or check Ebay for a parts machine that you can salvage one from. I believe that the volume control from an SX-850 will be the same, so you can search for one of those as well.
Good luck.
Dan
Posted on May 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: Can I connect my pioneer SX-255R stereo receiver
Yes, but it depends on your laptop hardware and software. We'd need to know a lot more about that side.
Posted on Jan 21, 2010
What does the photo button mean on my Pioneer receiver SX 205
You surely mean the phono button.
It's a preamp which adds 32 dB of gain. But first make sure you don't blow up your speakers by turning the volume down.
Different companies have different settings.
To enable the phono preamp in some systems, Press and Hold the Phono button for a few seconds.
Jun 21, 2015 | Pioneer Audio Players & Recorders
Pioneer elite sx-a6 keeps going to standby
I had a receiver that would shut off when I had the volume too loud. It was caused because the speakers were using too much juice. Does it work with less speakers or at low low volumes? Then this may be the case.
I solved it by getting a different receiver.
if it has nothing to do with volume then check your manual and settings for a auto standby feature that may be just putting the receiver to standby after a set time.
Apr 14, 2014 | Pioneer ELite SX-A9 HI-FI Audio Receiver...
Owner manual for pioneer sx 316s
You may download a copy of the operating instructions here.
Mar 17, 2013 | Pioneer Sx-316s Stereo Audio Video Home...
How can I control volume on my Pioneer SX-205 receiver from the couch?
There is a couple ways you can do this.
1.you can use the maufacture remote control, or if you dont have one you would need a universal.
2.If your receiver is hidden, or behind closed doors than you will need a radio frequency capable universal remote
Jan 07, 2011 | Pioneer SX-205 Receiver
Good luck.
Dan
May 19, 2009 | Pioneer Audio Players & Recorders
"muting" shows up the screen and I no longer get volume, can not the muting off as I can not see where I would change that setting.
Are you sure it's not the TV telling you that it's muted? I went down the tubes on that one myself.
The receiver's Mute can be defeated by just rotating the volume knob upward. Ditto with TV's.
May 11, 2009 | Pioneer SX-205 Receiver
PIONEER SX-205. Left chanel out of order. How to solve the problem?
You haven't mentioned what you have done to isolate the problem so I have to ask some stupid questions.
Is the Left Channel failing no matter what source you select?
N: Source problem / Identify the source and ask another question with new data
Y: continue...
Turn the receiver OFF.
Toggle the Tape Monitor Switch up a number of times to wear off any oxidation. Any change?
While you're at it, toggle, twist and operate every control throughout its range for the same purpose. Lower the volume.
Turn the receiver ON.
Tune an FM station.
Swap the Left Speaker leads and the Right Speaker leads at the receiver. Did it move with the speaker?
Y: bad speaker or wire
N: internal receiver problem.
Apr 03, 2009 | Pioneer SX-205 Receiver
Dec 06, 2008 | Pioneer SX-315
Direct TV remote codes for SX-315
hello i have a pioneer sx-315 it plays great but the sub performs badly.they sound is very low.they really need to perform better.if anybody know any sub that work better please let me know.
Nov 20, 2008 | Pioneer SX-315
391 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
