Question about NorStar Meridian M7310 Phone
Remove a restriction on a phone
The previous office manager set a phone that would not allow long distance calls. I would like to remove that restriction from the phone. How do I accomplish this?
  • Carl Navarro
    Carl Navarro May 11, 2010
    This is a question you should ask your phone vendor. The problem here is that you could be a disgruntled employee who has a restricted phone or you could be the new office manager, or the teenaged employee of a retail store.
    "If we tell you we'd have to kill you".
  • John Baker
    John Baker May 11, 2010
    can you access the programming mode?
  • 146 Answers
SOURCE: Calls not going through
it depends on where you live and what telephone company you are with...you will need to contact your telephone company and ask for the temporary ( call by call ) caller rejection unblocking code.( eg the code will be different in the UK compared to say the USA ) Please note that this will reveal your number to the called party thus enabling the call to go through. ( assuming you have your number permanently withheld as is implied by your comments )
Hope it helps.
Posted on Jan 16, 2008
  • 108 Answers
SOURCE: Restrict a mitel superset from dialing 1900 and international calls
What Mitel system are you using and what are the numbers you want to allow and what extension are we talking about ??
Posted on Jul 28, 2008
cnavarro
  • 2460 Answers
SOURCE: D1232 Panasonic - Removing Long distance restriction
Changing the Class of Service COS of that extension to "1" will allow it to dial anything.
In a TD system, that is a 2-step process, because you have to find where the extenion jack is located in the system.
Go into programming and dial 003. If you press the SP PHONE button, it will step you through all the ports in the system and give you extension numbers. To start 01-1 will be 101 01-2 201 02-1 102 etc. Since you're in a motel, it should be renumbered to match the rooms and if you started with 100 or eliminated 113 your whole plan may be different.
Once you find the jack number for your station, press the HOLD button and dial 601 SP PHONE and the 2 digit jack number from above. You will be looking at your extension COS. Dial 1 STORE and it will turn off that extension's toll restrictions.
Please rate this solution and let me know if you had any problems following this instructions.
Carl
Posted on Dec 12, 2008
  • 27 Answers
SOURCE: meridian m7324 - another phone in office - DND - unable to remove
You almost had it right . You need to do this press the feature button then # 85 to remove the DND .
Posted on Feb 05, 2009
  • 63 Answers
SOURCE: Restricting long distance
in system programming you will need to restrict phones to localcalls only
Posted on Feb 26, 2009
How to Change COS (Class of Service) Password
If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
You should now be able to call 9+1+area code+number, with no restrictions.
Mar 25, 2014 | Nortel Norstar M7310 Display Phone
I need to block certain extensions from being able to dial long distance
Best way to do that is to sit down with the manual and look at programs 400-408. At a minimum, if you restrict 1 and 0 in a table and assign it to your extensons in 405, those phones can't dial long distance. That's fairly worthless in today's calling climate when some carriers let you dial just 10 digits or you have to dial 1 for any local call outside your area code. 404 lets you build 8 tables of 10 number sequences each for restriction and 407 lets you build 8 tables of 10 number sequences for allow. For example You could put 1 HOLD HOLD HOLD (hold is the wildcard) in one table and entry of 404 with traditional dialing and that would restrict all 1+ long distance. Then, in 407 5 of your entries in one table would be 1800, 1888, 1877, 1866 and 1855 to allow toll free calling. These tables get assigned to extensions in programs 405 and 408. A simple restriction (ie local calls only, internal calls only) get assigned in 401. There are some other tricks and, above all, remember that you have to keep 911 availabe for access and allowing 0 is never a good idea because 0 alone will get the operator and that defeats the purpose of toll restriction.
Other tricks involve custom CLASS codes. You need to account for the clever worker who dial *67. That gives them second dial tone and they can dial the world. It would be easy if you could block first digit *, but you ought to allow *57 for nuisance call trace. If you have the above where long distance is dialed with only 10 digits, then you can always start with HOLD HOLD HOLD in a table and allow 911 and the local area code in an allow table. The table digits can be up to 12 so you may have to go to 6 digit screening in allow tables for local exchanges. In my area, we have 10 digit dialing and 419352 419353 419354 (among others) along with 567213 are local calls. If I were programming a customer 6 miles to the North, there would be extensive programming in both area codes.
Outside of that, it's just a function of analyzing your local calls, area codes, how a call is dialed, and building your tables. We do this with billing by the hour :-)
Carl
Apr 07, 2011 | Lucent PARTNER18 Corded Phone
The previous owner of my phone set it so that it won't dial out long distance calls. how do unblock long distance?
Hi To do so you can : - ask your service provider to limit the calls. - Find whether the previous owner has additional kit to limit the calls service and remove it Regards, jay
Feb 21, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
I have a nokia 6233,but its restricted with sim ,so you may please send the restriction code to me and WHEN I SWITCH ON MY NOKIA 3100ITS SHOWING PHONE RESTRICTED AND IN DOWN SHOWING UNDO WHEN I PRESS UNDO...
RESTRICTION CODE:
To get restriction code you have to call your previous service provider. This code is provided to prevent in case of theft taken place the other person cannot use your phone in other networks.
While you get the restriction code ,the previous service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only.If they are satisfied with your answers they will provide with the restriction code.
These codes are always free.DONOT pay money for these codes.The website which provides these codes are fake.DONOT trust them.
Thank You
Jan 05, 2011 | Nokia 6233 Cellular Phone
M7310 has lines 1 & 2 restricted to local calls only...HELP
Sounds like a 6x16 system, if you open it up, can you see on the right hand side 6 ports for your telephone trunks?
Ok... depending on the software level... enter the programming of the system, via **266344 and password 266344 (these are default passwords: might not be your passwords?)
Ok, once in you will see: TERMINALS&SETS (this is where your template to maneuver will come in handy) hit enter, and type in the sets that you want to change (ex 24) --> Look for RESTRICTIONS hit enter --> look for SET RESTRNS --> FILTERS --> change Normal to 2 and Night to 2 and Evening to 2 so on and so on.
This is the default to give no outside restrictions for your sets.
Mar 17, 2009 | NorStar M7310 Corded Phone
Jul 22, 2008 | Lands Phones
How di remove call barring from nokia 5500d
Call barring
Call barring (network service) allows you to restrict the
calls that you make and receive with your phone. To
change the settings, you need the barring password from
your service provider.
1 Select Menu > Tools > Settings > Call barring.
2 Scroll to the desired barring option, and to request the
network to set call restriction on, select Options >
Activate. To set the selected call restriction off, select
Cancel. To check whether the calls are barred, select
Check status. To change the barring password, select
Edit barrings passw.. To cancel all active call barrings,
select Cancel all barrings.
Call barring and call diverting cannot be active at the same
time.
When calls are barred, calls still may be possible to certain
official emergency numbers.
Apr 09, 2008 | Nokia 6288 Cellular Phone
Restrict call in model k750i of sony ericcson
Hi there.. block the incoming call barring feature. we can restrict incoming calls and add prefered people who are allowed to call. this feature is present on most sony ericsson phones.
to enable it go to settings->call settings->manage calls->accept calls. add the allowed people phone no.s in the list and turn on the "only from list" you will not get call from people except one in the list.
ok
peace!
Feb 17, 2008 | Sony Ericsson K750i Cellular Phone
Restrict a number from the list
Sorry but there is no blacklist option in your phone (only a whitelist).
Feb 01, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NorStar Meridian M7310 Phone Logo
255 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
