Question about Dishwashers
Will not fill with water and the tablet does not drop it starts up and then just stays on that same cycle position
  • 1 more comment
  • yakkers Sep 11, 2008
    my dishwasher is a westinghouse 921 freestyle and will not fill with water. i purchased it 2nd hand and have connected all hoses and turned tap on
  • bazamoza Sep 11, 2008
    matsui ms2s is the model number ... it is the timer model ..it seems to start as normal makes all the noises but just does not fill with water and the dial doesnt move around no matter how long it is switched on for ..thanks
  • robert samples May 11, 2010
    need the brand and model number and do you hear any noise is it electronic control or timer mod
    President:
  • 1,314 Answers
Yakers hope you can read this too the first thing dish washers do when you turn them to start is drain to get any left over water in the sump out then they fill then start wash cycle bazamoza id say you have a bad timer motor you can advance it manually one click at a time if you hear the water valve kick in then replace the timer if not reply to this post for further action
yakers check the float in the tub to make sure its engaging the safety micro switch pull the kick plate off at the bottom and find the rod from the dome in the tub and see if its engaging the micro safety switch that keep it from over filling
if all that's good then reply to post
Posted on Sep 12, 2008
How do you clean the pump filters?
Two possible problems
- You may have a problem with the water heater.
Tablet need to reach a given temperature to be dissolve
- Check if the water arm do turn ans spay water. To test, turn to a fix position, start the dishwasher and open after the the start of the cycle. Open the door and check the position of the arms.
If one of the arm is not turning, check the water holes One of them may be blocked
Oct 18, 2016 | Dishwashers
Why isn't the dishwasher tablet melting?
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have a problem with my dishwashwer. At the end of the cycle the dishwasher tablet is still intact and the dishes are still dirty. How can I resolve this? ?
The problem you describe points me towards the conclusion that the dishwasher is not filled with water. Another scenario is the motor is seized and not circulating the water.
I do not think that the soap dispenser is broken, as without soap these dishwashers do a fairly good job of cleaning.
There should be a small thing inside the dishwasher called a "float", which is a sensor that stops the dishwasher from filling if it thinks it is full. Try wiggling that and see if soap has jammed up the float in the "full" position. It should be in the front left or right corner.
If the dishwasher hums and sounds different then you may have something jammed in the motor.Start a cycle and look in the dishwasher after the motor starts, is there enough water? (1-3 inches deep).
Aug 12, 2010 | Dishwashers
Washing machine will not fill with water just aggitates
Check the float bulb in the bottom of the tub and the switch below the tub. It may be stuck in the up position telling the computor that the water has filled. The timer is not supposed to advance to another process engagement until the water floats the bulb and changes the bottom switch position.
Jun 21, 2009 | GE WBSR3140DW Top Load Washer
My dishwasher Bosh Model SHU43C06UC has the drain clog
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Apr 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Descale red light, wont go off, and can i use any delcale tabs
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Mar 12, 2009 | Bosch Coffee Makers & Espresso Machines
Water fills Cycle won't start
Often the lid switch needs replacement. I can become cracked from the lid being dropped.
Nov 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Dishwashers Logo
174 people viewed this question
Top Dishwashers Experts
