Question about Brother HL-2040 Laser Printer
Wrinkled jammed paper
My printer randomly jams and wrinkles the paper no matter what weight paper I use, except for Intuit check forms. Can you remedy?
  • kutters Sep 18, 2008
    my printer fots a lot and stinks when it eats chili, it is quite gross and smells of ****-stained poo nuggets
  • 4 Answers
Paper weight to light change it.
Posted on Sep 27, 2008
Why does my copier "rear jam" and wrinkle the paper after the fuser?
replace the fuser and check for a blockage after the fuser
Jul 11, 2014 | Sharp AL 1631 Copier
Envelopes wrinkles after running through printer
Minolta does recommend stuffing the lip inside the envelope before running. But I think it only helps with jamming. Plus high humidity can cause wrinkling.
Mar 14, 2013 | Konica Minolta Office Equipment & Supplies
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
My paper is coming out wrinkled when I print?
Please check the following steps:
1.Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Turn off the printer. Remove any paper trays. Look for wrinkled or damaged paper.
3. If necessary, remove the toner or ink cartridge.
4. If you find a piece of jammed paper, remove it.
5. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
6. Replace the toner or ink cartridge and paper trays.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | HP LaserJet 3030 All-In-One Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Wrinkled Paper
Check paper path,especially near fuser.If all ok fuser is faulty.
Jul 10, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Brother HL-2040 Laser Printer Logo
466 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
