Question about HP Pavilion dv9000z Notebook
HP dv9000 Laptop screen started flashing and then went black on my laptop (hp dv 9000). Took out harddrive and everything is still on it but when i hook up an external monitor it says operating system not found
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Posted on Sep 18, 2008
Hp dv9000 will not turn on the blue lights come on and goes off right away. I bought a new cord and adapter and it does the same thing. I did try taking the battery out and holding power button for 30 sec...
vast posts here on black screens of deathh
the screen is 100% black and never once shows text or that HP logo. 100% dead black, then that is the screen back lamps dead
as most long ago did, go dead , just not yours.
called the CCFL lamps dead.
ok the battery out test1
the other check is the fan is the fan blowing, it must or the CPU overheats fast and (it shuts itself off, like magic (intel inside)
see slide show here for Laptop link packup causes.overheated
http://www.pcdied.com/overheated.html
my guess is it is there, below... as all do every one at 20k hours.
see flash light test. there. on test one, do that.?
see test #1 (battery out, ac pack connected and working)
http://pcdied.com/black-screen.html#Basic-basics-101
if the flash sight trick passes, (see data) ask how to fix that
or read the service manual at HP.
see the list of HP , with CCFL here. dv9000 is it.
http://pcdied.com/monitors.html
if yes, ccfl dead
see here
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xdv-9000+ccfl.TRS0&_nkw=dv-9000+ccfl&_sacat=0
1% fail this way for inverter bad, 1 in 100.
see same page above for inverters sold the lamps run of it and it makes 500 to 1000vdc to do that,, HV inverter.
Oct 30, 2017 | HP Pavilion dv9000z Notebook
I have HP DV9000 laptop when i switch on it powers but the display is like in safe mood i cant see anything
i am mr john uche aaron
in Nigeria ,
my hp pavilion dv 9000
cannot bootup
but display only light on the quick bar
and blank screen
what is the solution
Dec 12, 2010 | HP Pavilion dv9000 Motherboard
Dv 9000 what lcd fits it
1) 17 inch WXGA (1440 X 900 Pixels)
Here's an example;
http://www.screentekinc.com/HP_Pavilion_DV9000_Series_DV9009NR--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Another one;
http://www.pcpartsltd.com/hp-pavilion-dv9000-screen-170inch-lcd-screen-p-1791.html?zenid=ihi8on44ad0gdnuab8ipt2ujb5
MAIN THING > Match the Part Number on the back of the LCD screen to the one you are going to purchase.
It isn't just whether the screen is the correct size, and dimensions. Whether it is a glossy finish, or matte.
It is that the cabling on the back of the LCD screen is correct, and the LCD screen matches the Inverter that is installed.
2) Just to add;
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
Nov 04, 2010 | HP Computers & Internet
My hp pavilion dv9000 17 power on but see black screen
If your 9000 is under two years old, you should contact HP customer care and have unit serviced under warranty.
HP has had allot of problems with the 6000 and 9000 units and in response has offered an additional year from date of purchase.
Its worth a shut. Doesn't cost a dime.
Hope this information has helped you.
Oct 11, 2009 | HP Pavilion dv9000z Notebook
Everyb time I turn on my hp dv 9000 loptop the blue keys turn on but the monitor does not?
I have seen alot of dv9000 inverter or screen problems. Nice laptop but it does have its problems. I would check the inverter first, they are relatively inexepensive.
Aug 02, 2009 | Computers & Internet
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Hp pavilion dv9000 blue lights on won`t boot stuck just cli
Sounds like the harddrive went bad.
Some people call it the click of death.
Put the laptop to your ear near the harddrive and you will hear the clicking coming from there.
Good news is that it's easy enough to change the harddrive.
Bad news is you lose all your data to this point.
I hope this helps and i'm sorry that happend to you.
Dec 24, 2008 | Acer Aspire 5315 Notebook
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
HP PAVILLION dv 9000 laptop new bios instalation instructions
you need to go to HP web site , and down load the lates bios to update system
Mar 28, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
326 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
