Question about Frigidaire FEF352 Electric Kitchen Range
Fridgedaire Electric Kitchen Range
When we plugged the stove in, there were sparks, popping sounds, and some glowing particles came out of the back of the stove. Now it takes forever for the burners and the oven to heat up, and the burners never fully get hot or red, even when left on high for over an hour.
    President:
  • 1,314 Answers
Shut your oven off at the breaker and then pull it out and check the power cord where it connects to the ranges terminal block let me know what you find
Posted on Sep 11, 2008
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
Oven quit working. stove top works
the oven has a glow plug to ignite the gas. remove bottom tray in oven, and turn it on. if glow plug does not get hot, it should be a bright orange color. replace the glow plug if it does not operate properly. if you do it yourself. be very careful. the glow plug is very fragile and must be handled with care. Ive broken one before! just a slight tap will break them. good-day! ( for electric ovens).
Apr 09, 2014 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Frigidaire crown series electric stove just delivered.
Hello - I would first suggest confirming that the range is plug to the proper voltage (120/240 Volts 40/50 Amp). Was there anything located behind the range before pushing it back? From what you have described it sounds like the control board will need diagnosing. Contact a professional to move forward accurately.
Oct 18, 2012 | Frigidaire FEF352 Electric Kitchen Range
My Fridgidaire FEF366BCC just popped my breaker
This sounds like a main control problem. More specifically like one of the relays is shorted. You will need to acess the main control and carefully inspect it for any burn marks. If you don't see any disconnect the main power supply wire going to the main control. Then plug it back in if it trips the breaker the problem is in the power cord or wiring from the cord junction to the main control. If it does not trip the breaker the problem is the main control. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Jul 21, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Electric range heard a loud bang then it went dead
I WOULD DISCONECT THE POWER AND REMOVE THE BACK PANNELS AND LOOK FOR A SHORTED WIRE OR A BURN MARK ON THE BOARD. ALSO CHECK WHERE THE CORD ATACHES TO THE STOVE. GOOD LUCK!
ERIC
Jan 17, 2010 | Kitchen Ranges
Kenmore elite gas range clicking sound
If unplugging it for a couple minutes and plugging back in does not rectify then it sounds like a bad spark module or a shorted wire inside. All 4 should spark at the same time when any burner is used. (Does trying to light a burner make the other 2 spark too?)
Eric
Jun 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven does not work
somthing shorted those are easyer to repair because theres evidence some where.turn off power and surch 4 that burnt spot then repair accordingly.most common on electric stoves are the element shorting you would see blistering on the element.God bless,tom
Jan 01, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Frigidaire FEF352 Electric Kitchen Range Logo
137 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
