Question about Intel Motherboard
My computer wont reboot in any mode
I have a azus amd athlon 2400+duo core what could be the problem i assume in the bios settings that i myself by playing around with things i dont know enough about that set wrong that could possibly be put right anything you sugest i will welcome,alan,wales,uk
  • 67 Answers
If it wont boot because you played with the BIOS settings, try resetting the CMOS. Turn off the computer, unplug the power cord, open the PC, look for the CMOS reset jumper(it is near the CMOS battery or just look at your manual for a clearer location. It has three pins). At default the jumper is placed at pins 1 and 2. Move it to pins 2 and 3. Wait for a minute. Then place it back to pins 1 and 2. Or you could take off the the CMOS battery and wait for maybe 5 minutes.
Posted on Sep 12, 2008
How Do I unlock CPU cores with Bios on MCP61M-M3 motherboard?
The motherboard supports AMD socket AM2 single-core Athlon 64/ Sempron and dual-core Athlon 64 X2/ Athlon 64 FX processors with 2MB / 1MB / 512KB L2 cache, which is based on 64-bit architecture. It features 2000 / 1600 MT/s Hyper Transport Bus, dual-channel un-buffered DDR2 800 memory support and AMD Cool 'n' Quiet! Technology.
The BIOS changes it on it's own when add a dual core.
Here is the PDF file on this board. Chapter 2 explains the Bios.
Jul 03, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Videocard not working
Try removing the new card, booting into BIOS, change your video setting the slot of your card: I believe your card is PCI-E, save changes and exit. When it starts to reboot, turn the computer off, install the new card and then try rebooting again. You may also have to boot into Safe Mode\Uninstall the original video driver or disable that video component and then try rebooting your system.
Mar 29, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
My desktop computer shutdown & restart after my amd sempron upgrade to amd athlon64 5200+
make sure the settings in bios are correct for that processor. you might need to flash the bios to accept the new processor as well. without any other info thats the best solution i can provide. hope it helps!
Feb 21, 2009 | AMD Athlon 64 X2 Dual-core 5200+ 2.60GHz -...
How to get my CPU to run at the correct speed
Your FSB should be 400 MHz for the Athlon XP 3200+ processor.
CPU-Z shows your core speed at 1320 and your FSB at 241. If you multiply those numbers by 1.66, you get 2200 and 400. So all you have to do is get the board to the correct FSB speed of 400 and your core will be right.
There are two MSI boards with the number CPU-Z gives you. Board 1
Board two
The AMD page doesn't show the core voltage for the older processors, they do for the current ones. I looked at the MSI site and didn't see their manuals online for the motherboards either, sorry. I'm not positive it was changed using a jumper though, you saw nothing in the BIOS to set it? If the jumpers are on the board they may be labeled FSB and you can try the various positions.
Hope that helps, good luck.
Jan 11, 2009 | AMD ATHLON XP,3200+,512k Cache...
Which is a better processor?
The AMD Phenom x4 is actually cheaper with 4 cpu cores compaired to Core 2 duo which has 2 cpu cores, you will get a better deal for less money on a AMD x4.
Heres a chart you can look at,817.html
I just got myself the AMD Phenom 9650 for 150usd
The core 2 duo e6600, which I would recommend from the core duo series costs around 200 usd.
Note that the Duo only has 2 cpu cores. You get double the power on a phenom 4x with 4 cpu cores
So the phenom is definitely the best choise! (double the power for 50usd less)
Anything else?
Nov 19, 2008 | Computers & Internet
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Intel Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
