Question about Sony Cyber-Shot DSC-P92 Digital Camera
Problem with the LCD Screen
This is a bit of a newb question but anyway. images simply aren't appearing on the LCD screen other than those for camera setting and date, battery level and etc. But nothing I would wish to take a photo of, all there is there is black (though it does react to light)
This is for me a new camera; though it has been in previous use and many things were already set up (such as the date) before hand. I've tried reading the manual and messing around with the settings but nothing is forthcoming, am I missing something?
  • rickdude Oct 29, 2008
    I've got the same problem with my dsc-p92,having looked into the problem on the net it seems to be a ccd image sensor problem, that has affected a number of other sony digital cameras
I think your problem is the ccd image sensor,this is a common fault with some sony digital cameras
Posted on Oct 29, 2008
Lens screen stuck open and no image on LCD view screen.
It is jamming, the only really fix is to have it repaired, that costs a lot and it is sometimes better to just replace the camera.
Mar 15, 2014 | Sony Video Cameras
Washed out colour on d 5100 images
If the colors are washed out on the LCD screen but appear OK on your computer, the problem is likely with the LCD itself.
If the color is washed out in both the LCD screen and on your computer, you can try adjusting menu settings to intensify the color on the images. Also, you might want to reset the camera to its default settings. I can do that on my D-90 by simultaneously holding down the "AF" and "+/-" buttons on the top right hand side of the camera. Holding down those buttons for about ten seconds will restore the default settings.
If these steps don't help, return the camera to the seller for a replacement.
Dec 02, 2012 | Nikon D5100 Digital Camera
Lcd screen is blank
Turn on the camera and press the DISP button 2 - 3 time and see the lcd light up or not.
Aug 12, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Hi, I purchased a replacement LCD screen for my SD3500 from Rongstar DigitalInc. Since I've learned they do not have a good reputation and to make matters worse the LCD screen will not function...
I had a similar problem with a Canon camcorder. I replaced it with a new LCD screen from Rongstar Digital, and it works! Saved a $350 camera for $20! However, installing the new LCD was very difficult, and is not meant to be done by amateurs. You have to be sure the tiny connectors and screws are placed exactly right and in the right order. Don't blame the seller if it does not work!
May 17, 2011 | Canon PowerShot SD3500 IS / IXUS 210...
Someone sat on my es-55 samsung camera, when i put it on an ink blot picture appears on the screen, this might be the lcd screen , the lens is okay as it still slides out.How do i fix it?
Hi
Does the 'ink blot' appear on any pictures you are taking or just on the Samsung ES55 LCD screen?
If it just appears on the LCD screen it's probably been damaged when it was sat on, and the only option would be to replace the LCD screen by contacting a Samsung service agent in your region.
If the 'ink-blot' image is appearing on the pictures you are taking then check the lens is clean - be careful not to extert to much pressure on the lens when it is retracted.
if the lens seems clean, as a last suggestion change memory card, or totally reformat the card that is in the camera - if the card has become corrupt the images may not be displaying correctly.
I hope one of these few suggestions sorts your problem.
Regards
David
Jan 17, 2011 | Samsung Cameras
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Appears dark color and made my camera phone always stand by..
move your finger... retart stop taking pictures in the dark outside... NEWB!!!!!
May 09, 2010 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
LCD screen purple and distorted in Shooting mode
There is recall on this model for this problem, Go to Canon USA web site, Look up Service advisory, CCD malfunction N/C to repair.
Feb 24, 2009 | Canon PowerShot A80 Digital Camera
LCD has gone blank
Hi this is tech crazy
Based on the information you have provided, it appears that you may have
encountered this issue. To determine if the CCD (image sensor) is
working properly, please follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service
Hope this solution helps you a lot
Please rate me on the above said solution
Feb 04, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
DOWNLOADING TO PC
Hi during dowloading pictures need the camera knob to display or where you can view pictures and video. connect usb the detection will view on screen and follow screen instruction.
Jan 20, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Sony Cyber-Shot DSC-P92 Digital Camera Logo
98 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
