Question about Carrier Heating & Cooling
Lennox cgs16 series roof top unit, flame lights for 6-8 sec then drops out, switches (roll out, high limit, ventor,ok)
tborn6
  • 700 Answers
SOURCE: I need to adjust the
If you mean the ambient lockout switch it shpopuld be oin the outside unit and all that you will need to shut off is the outside condenser before you open the panel. ther is a disconnect that you will have to throw either right by the unit or inside of a main breaker panel.. Hope that this helps and Thanks for using Fixya
Posted on Dec 25, 2008
SOURCE: seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Posted on Jul 24, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have 2 dometic roof
Hi, unit # 2 sounds as though the run capacitor may be open, shorted, ect.When you say you changed relay, I assume you were talking about the capacitor. If the motor didn't run when you changed it, you do have a bad winding, or open as it just hums. Unit number one may just be the stat switch is only wired to high, or they only have a single speed motor in the unit. You will need to see on the side of the motor or see how many leads are coming off the motor to see if it is a 1, 2, 3, or even 4 speed motor and go from there. It should be a 3 speed to run your heat and a 3rd wire for a spare, capped off. Please let me know if you need more help. I know your condenser fan motor is faulty if the run cap is good, even though the shaft spins free.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Please rate me on this :))
Posted on Nov 29, 2010
  • 1015 Answers
SOURCE: i have a dayton fuel
It sounds to me like your draft motor is probably shuttimg off on thermal overload. They will get to hot and shut down until the motor cools down then run again.But by that time it's caused other trouble so I think you need to replace the motor first and then see what other problems it has caused.I hope this helps you and thanks.
Posted on Jan 10, 2011
johnjnail
  • 1702 Answers
SOURCE: 1998 Class "C" - 600
most likely cause would be a seized compressor, but try this remove the cover from the a/c unit and make sure the fan on the condenser is not sized up if the fan is free then you will most likely have to have the compressor replaced, and on most of these units it is cheaper to replace the unit then have it repaired.....good luck
Posted on Jun 05, 2011
4 red blinks, open limit switch. Replaced limit switch, still getting red blinks.
your ventor motor has to come on first to close limit switch,follow tubing from switch to ventor motor see iffu have 120 volts going to it, if 120 volts replace ventor motor assembley, no reset on board, board will reset every time u turn of power and back on
Dec 30, 2015 | Heating & Cooling
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
Trouble shooting light blinks 6 times showing open roolout!how do i fix that problem!
The flame rollouts are located in the burner compartment and attached to the sides or top of the metal housing around the actual burners. They are small and round and have 2 wires hooked to them. They are there for safety to detect if the flame is rolling out of the heat exchanger, caused by other possible issues. However, sometimes they do go bad and have to be replaced. Also, your rollouts are ran in series with the limits and may also be that. The only way to track it down is to have a meter that measures continuity and after the unit stops working, see which device you lost current through. Bypassing these can be harmful and cause major problems so I do not recommend it. One thing you can try is to make sure all filters are clean and the air flow throughout the house is "normal". These can cause the unit to overheat and trip one of the limit switches that I mentioned earlier. I also do not recommend watching if the flame is coming out of the heat exchanger causing a rollout to trip, but if it is, you could have a blocked flue pipe or other issues. I hope this helps or at least points you in the right direction. Good luck and happy holidays!
Nov 24, 2012 | Goodman GMS90703BXA Heater
Rheem furnace not heating.
Sounds like limit switch is tripped if all it does is start the fan. Is ventor motor running? If not check limit switch should be located below burner compartment. May be manual reset but probably not. Tap on switch and then check filter to see if plugged.
Mar 07, 2012 | Heating & Cooling
I have a reznor heater in my garage, it is flashing the code for open limit switch or open flame roll out switch, it will ignite but not put out any heat, and stay lit for a minute or two then go out. ...
I have the same issue, Appears that the fan does not start thus the high temp limit switch operates and the unit shuts down and the green light flashed three times. The open flame roll out switch is resettable manually in the top upper left of my unit. Were the manual shows the high temp limit switch, there is nothing visually located in the panel there.
Dec 11, 2010 | Heating & Cooling
My Goodman GMP 125-4 furnace has 4 blinking lights and we currently are unable to get it to come on. What might be wrong?
if this is an error code and you mean that the light blinks 4 times then it is the limit circuit. This could mean either the high limit or a roll out switch is open. the limit switch is right in the center of the furnace above the burner and roll out switches are probably somewhere around the opening of the burner. Follow the wires from the limit to find a roll out switch cause they are in line with each other and the rool out switch could have a button to reset it. However if the roll out is not tripped then you could need to change the limit. Only way to know is to check for continuity.
Dec 04, 2010 | Goodman GDS80904BNA Open Flame Heater
Set thermostat to auto switch unit to heat. Unit lights runs for a minute then shuts off. Fault light blinks4 times, msg. Open high limit.
Check air filter for blockage, clean off flame rod found in the flame pattern of the last burner that ignites, check high limit switch with multimeter to see if good (found above the burner box). Make sure room air blower turns on within 90 seconds of first flame.
Nov 28, 2010 | Goodman CLQ36AR49 Air Conditioner
My Blower runs 24/7 and the burner is not kicking on.... Is this a high limit switch issue?
It might be the high limit, but it could also be the roll out switch or the flame sensor. Start by ohming out the simple switches the high limit the rollout if the are good use a piece of light grit sand paper or some emery and clean the flame sensor. This is a rod that sits in the flame of the burner telling the gas valve the burners are lite and it is okay to keep the valve open.
Jan 15, 2010 | Ruud UBHC Air Conditioner
How do I clean a flame sensor on a 1993 Lennox Whisper Heat furnace. It heats,then the gas valve clicks and the flame briefly stops and starts again then the valve clicks again and the flame briefly stops...
You can sand the flame sensor but it sounds like another problem. Sounds like a limit switch or something in the control circuit, You need to have a service tech look at this. Ask for free estimate on repair. I have worked on hundreds of these units and they are sometimes tricky to work on. Lenox has come up with new controls for the whisper heat furnace to replace the old ones. If the flame sensor is bad the unit will try to light a few times and lock out and you ahve to kull power to the furnace to reset. If this is whats happening clean the sensor nd you should be ok If not you need help from a service tech.Rus
Nov 11, 2009 | Heating & Cooling
Lennox lf24 garage heater, starts then shuts down.
Here is a link to the manual for your unit heater:
http://tech.lennoxintl.com/C03e7o14l/mk6x6w5J5/503526e.pdf
The 4 flashes is a high limit or roll out switch is open. There are 2 or 3 little brown or black button looking switches with a little button on the top and a wire attached to each side. Press the button on each, you may hear a slight "click". If you do, that is the one that was open. Hope this helps.
Oct 31, 2009 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
