Mitsubishi CS-32207 TV
Problem for Mitsubishi CS-32207 TV
Mmitsubishi TV Blank screen
By exp001 on Apr 26, 2006
I have a mitsubishi TV. I have audio and video, I have high voltage on CTR but the screen is blank. when I use video in, I also have audio but the screen is still blank. How can i fix this?
Solution #1
posted on May 14, 2006
Somewhat Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1897 votes
Check the video in sockets on the TV. Some do actually have two, usually one at the back and the other on the front or side of the set.
When new they tend to be a little tight and people usually resort to twisting the plug to remove it. This can often twist the cable off the video in socket inside the TV.
Make sure the set is switched off and remove the back. Take a look at the cable running to the video in socket and see if it's connected. If not then simply resolder it back on.
It may not be the cure but always look for the easy way first.
BMW
Was this helpful?
Yes
No
Solution #2
Not Rated)
Boba
Rank: Wiz
Rating: 83%, 193 votes
Not easily, unless you can provide more detailed troubleshooting data.
What test equipment do you have and know how to use???
Oscilloscope?
DMM?
Isolation transformer?
ESR meter?
If you can "assist" with the troubleshooting I am certain that you can recieve repair suggestions.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi CS-32207 TV
Questions and Unsolved Problems for Mitsubishi CS-32207 TV
Do you recommend Mitsubishi CS-32207 TV?
Answer
Answer
when I turn the television on it hums for a couple of seconds and then it turns itself back off. It... (More)
Answer
Can't Acces Menu. Have a Cable but NO REMOTE
Answer
my mitusbishi tv has sound but no picture Can it be fixed?
Answer
I have a 14 yaer old MITSUBISHI TELEVISION and only have two s-video connetions in the back-I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
