Question about Asko Washing Machines
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP appreciated.
    Genius:
  • 1,239 Answers
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Posted on Sep 11, 2008
My Asko 10505 washing machine used 110 litres water for one load. Is this too much water?
certainly is
check that the drain hose is above the washing machine into a tub as it may be running out as the tub fills
there are no valves , just the height of the hose above the tub
Oct 20, 2015 | Asko Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Power it off and on, again
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Sep 11, 2008 | Washing Machines
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
Asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Mar 06, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
193 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
