Question about Movado Watches
My watch is running slow battry checked out fine
Hello, i wonder what size battery does a diesel dz5063 watch take? Thanks
it uses SR920 size of battry. i hope i had been helped you.
Aug 12, 2011 | Diesel DZ4029 Watch
My Swatch Irony watch has recently been running slow. I thought it might be a low battery, but after a replacement, it still loses time (a few minutes each day). Any ideas?
Thank you for contacting Fixya,<br /> I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br /> You can contact Swatch at:<br /> <a href=""></a>
Aug 24, 2010 | Swatch Irony watch
The watch is running slow
Have you had the battery checked? If not I would suggest that first, and if not the battery, then prob time for routine cleaning, adjustment. If you dont have a local place then check out:
Good luck.
Aug 23, 2010 | Giorgio Armani Armani Automatic watch...
Runs slow by 60 seconds a day. day/date also turn a few hours late
Your watch is in need of service. Running slow is an indication the oils have dried out and are not lubricating any more. When oil dries it gets sticky like a soft glue. A mechanical watch can have the power to force the gear train to run but the constant drag on the dried out thick oils will cause it to run slow.
All watches should be serviced regularly.
The date issue is due to the hands not being installed properly. This is an issue that will be taken care of when the watch is serviced.
Hope this helps.
Yellowstone Watch Inc.
Oct 27, 2009 | Seiko Divers Automatic watch
Same problem
Yes. Timex uses a CR or lithium battery and they are notorious for not having enough power toward the end of their life to run the analog side of the watch.
Sep 22, 2009 | Timex Sports Ironman Triathlon 50-Lap...
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
New watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
May 11, 2009 | Kenneth Cole KC1104 Wrist Watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Watches Logo
444 people viewed this question
Top Movado Watches Experts
Jimmy Accardi
Are you a Movado Watch Expert? Answer questions, earn points and help others
