Question about Lands Phones
I have purchased two extra handset charger and accessory for a Uniden phone and when I set it on the unit it reads ---registering and after a moment it reads registration failed. I have two handset that read the same thing. Could you please help???????
  • 38 Answers
Did you first charge the phone for at least 6 hours? Both the phone and the base need to communicate and if the hand sets are not charged they will not have enough juice to talk back. Hope this helps.
Posted on Sep 11, 2008
  • havinfunyet Sep 11, 2008
    Sorry if this was inappropriate to you but after reading your question I don't understand it. Could you clarify what a handset charger is? Or is a handset charger and accessory one thing? If not what accessory? Would like to help if you could clarify. The more I know what the specific problem the more help I can be.
    Typically on the handsets you charge your phones that are seperate from your base unit. On your base unit you push the locator button. Once the phone rings then that handset is now registered with your base unit. On your 2nd phone you repeat the step. Hope this was better help than my first try.
I bought some handsets but they were registered to another base. How do I deregister without the base
First, select Deregister HS from the main menu. Secondly, press the red phone button and the # key simultaneously for about 5 seconds to finish deregistration. You will then see a message telling you to place the phone in the cradle of the base unit to register it to your unit. An "operation complete" message will confirm that the handset is now registered and ready to use. Good luck.
Jan 16, 2011 | Uniden TCX905 Cordless Accessory Handset...
I have a uniden TRU9488 preregistered handset from factory, which for years no problem, but stupid me thought "what is this register" and hid register, and now my handset won't work. followed...
What happened is you have deregistered your handset from the tru9488 base. To correct this, you must register that handset with the base. See https://www.manualslib.com/manual/185023/Uniden-Tru9488.html?page=24 for short and sweet instructions for doing this, reproduced below:.
Registering.TCX905.Accessory.Handsets,.or.Other.Compatible.Handsets If.you.purchase.an.accessory.handset,.you.need.to.register.the.handset.before.use..Only.one.handset.can.be.reg-
istered.at.a.time..Handsets.supplied.with.the.phone.are.registered.to.the.base.by.the.factory..When.charged,.pre-
registered.handsets.display.a.handset.ID.number..Handsets.that.have.not.been.registered.display.MODELS.VARY!.
PLACE.HANDSET.ON.THE.BASE.FOR.REGISTRATION.OR.REFER.TO.OWNER'S.MANUAL..(If.an.accessory.
handset.has.ever.been.registered.to.a.base,.you.must.reset.the.handset.before.you.can.register.it.to.a.new.base..
See.Resetting.the.Handsets.on.page.24.)
When.you.register.an.extra.handset.to.the.base,.the.handset.ID.will.be.assigned.
M o d e l s v a r y !
P l a c e H a n d s e t
o n t h e b a s e f o r
1)
Before.registering.the.TCX905.or.other.extra.handset,.the.battery.pack.MUST.be.charged.for.5-20.hours.
2)
With.the.base.in.standby,.press.the.MENU.soft.key.
3)
Move.the.cursor.to.select.REGISTER.HANDSET..Press.the.OK.soft.key.
4)
On.the.handset,.press.and.hold.[#].until.you.hear.a.beep.
5)
While.the.handset.is.registering,.HANDSET.REGISTERING.will.appear.in.the.dis-
play...
When.REGISTRATION.COMPLETE..is.displayed;.the.handset.has.been.registered.to.the.base...
If.REGISTRATION.FAILED..appears,.please.try.these.steps.again.
Aug 10, 2017 | Uniden TRU9488 Phone
Purchased addt'l handset to work with my CEZAI2998. It has a corded handset in the base and an accessory handset with charger. Needed another accessory handset; purchased EZX290 but can't get it to...
The CEZAI2998 does allow up to a total of 6 handsets, but your issue is that the EZX290 handset is not one that will function with that system. I have listed below the compatible handset models for that Uniden unit and as you can see the EZX290 is not supported. Sorry to be the bearer of bad news, hopefully you can exchange it for a compatible handset. Good luck!!
EJ
Compatible with select Uniden handsets
Including models DCX150, DCX200, DCX210, DCX290, DCX300 and DWX207 for wide-ranging compatibility.
Apr 10, 2010 | Uniden DECT 6.0 Cordless Telephone...
I have a tcx905s handset that will not register to my tru9496 base. Uniden claimed that 905s units will work with this base. However, they said that refurbished units will not work. Is this true?
Not sure about the refurbish issue...but have you tried to de-register the handset by holding down the end key and the # key, then placing on the main base unit to register with your system.
Sep 25, 2009 | Uniden TCX905 Cordless Accessory Handset...
We had Uniden model TRU8866. Handset #2 was damaged and lost. We purchased a new phone through Uniden. It says Set #4 on it. We would like it to say #2 The new phone is a Power max5.8ghz.
In order to re-register handsets with TRU8866 base unit, you have to reset the base unit, de-register the handsets, and then re-register the handsets. To reset the base station, disconnect the power from the base and then press and hold the CID, Intercom, and Exit keys while you connect the power. Wait for the beep, and let go of the keys. Now re-register the handsets - the first one will become #1, and so on.
May 16, 2009 | Uniden Lands Phones
Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Sep 30, 2008 | Uniden DECT 6.0 Cordless Telephone...
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Handset Fails to Register
It is quite possible that you'll need to go into the menu settings on your base-unit and reset the unit or restore factory default, whichever option it gives you. Also, look in the menu on the phone to see if there is an option to reset the handset also. After resetting the unit and/or handsets, try to register the handsets again, one at a time. If that still does not fix the problem, you may have handsets that are not compatible with your system, or your system may not be able to support that many phones. However, if you have the right handsets, and your system can host that many handsets, then I'm confident that resetting the unit and re-registering your handsets should fix your problem.
Hope this helps! Have a nice day!
Apr 05, 2008 | Uniden DCX640 Cordless Expansion Handset...
PLEASE REGISTER!!!!!!!!!!
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger to register.
Dec 27, 2007 | Uniden Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
288 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
