Question about Motorola Mobility RAZR V3
Razor will not charge
Says unable to charge drained new batt tried other batt in phone and works just fine will not accept charge help
  • 38 Answers
My own razor does this also. the problem is the charging port on the phone. try using an electronics cleaner inside the port but do not oervsaturate. Otherwise if the phone is warrantied or you have insurance take your phone in and get it changed. I had a spare phone that i use to charge my battery. hope this helps.
Posted on Sep 11, 2008
I try to charge my razor using my blackberry charger but it wont work it keeps saying "unable to charge" why?
hello,
from explanation this means that you are trying to charge your razor with another phone charger , it will not work out for them self because they are not compatible .
what you need to get your razor phone is the type of his own charger ,but if you can not fine it own charger then you will have to go the store together with your razor phone then will help in locating it own charger that will work for with out any damage on your phone
thank you and thanks for using fixya.
Apr 11, 2010 | Motorola Mobility RAZR V3
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Unable To Charge Message on Razor Cell Phone stops working off charger. Battrey shows full
My v3 has done the same sometimes I couldn`t charge then taking it off charge it used to die.
Try a new battery.
Nov 09, 2009 | Motorola Mobility RAZR V3
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
V3 unable to charge
reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Feb 17, 2008 | Cell Phones
Unable to charge the razor
there may be a short in the wire or in the plug. try wiggling it around a little bit and see if you can get a connection
Jan 19, 2008 | Motorola Mobility RAZR V3
Motorola razor
you may need to have the usb charger port replaced....if that does not work try reflash the original firmware on the phone....for this to be done it is best that you take the phone to a mobile center close to you.
Dec 20, 2007 | Motorola Mobility RAZR V3
No charge
check the batt mayb your batt drained off... try using other batt.  if still doesnt work, probably you have a software or hardware failure...
but if it works w/ other batt try charging it, if still doesnt charge your phone charging section have a prob...
just visit your nearest service center to help you...
Oct 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Unable to charge :(
Does it say something like "charger not recognized". I remember having this problem with my razor, and it drove me crazy for several days, then it went away and has never returned. I may have also blasted all the txt messages away to help fix it to. Killing all the txt messages seems to help this phone if its acting up. Definitely speeds up the menu operation. Apparently 250 txt messages is its capacity, even though it will store alot more.
Nov 11, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
123 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
