Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Monitor goes blank
My monitor just goes blank after about a minute, it displays initially then goes blank although the power button is still lit. If I turn the monitor off then on again it displays then goes blank. I can repeat this procedure and the symptoms repeat itself. Help!
  • Terri Barth Sep 20, 2008
    I have the same problem, The monitor goes black and green light is still on. I can turn it off and on again and it keeps going black up to 8 times in a row. Has been doing this since 2004 and has been serviced, monitor replaced and the whole hard drive even replaced. I wonder if Gateway even knows what they are doing.
  • Victor Castro
    Victor Castro May 11, 2010
    if you tilt it and look at it from a glare of the light around you do you see any dimmed image?
    If you want to check it out its easily done if you look at it very carefully and push the windows Start button on your keyboard to check and see if anything appears. If you can check this I can tellyou what is wrong with it.
  • 45 Answers
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Posted on Sep 14, 2008
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor problems--screen is blank but power button lit
Check you video card first, if you can remove it, then have it clean, the contact with an pencil eraser, just make it sure wipe the eraser residue, then put it back again, also check the built in fan on your video card, make it sure it is running
Nov 02, 2009 | HP vs19 (Silver) 19" LCD Monitor
Blank Monitor on my DELL
Your display is having problems with the Inverter that generates high voltage to lit the lamp.
This issue is explained (including how to fix it) here:
Good luck
May 07, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor goes blank after 5-10 minutes
You may have a compatibility issue with your monitor. You computer may not be putting out enough power to support your monitor. Check your users manual on your monitor for output requirements. If the monitor's manual has a number to call, call the manufacturer to see if there are any compatibility problems between your computer and your monitor and calling the people who built your computer as well. Get as many scenarios as you can to find a solution. Hoped this helped.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor revives only after cycling the power many times
Unscrew 4 screws on the back side. Place the monitor with the front up and open it along the upper seam. Turn it again and lift the back cover. Shift the inner case "up" and take the button holding plate out - it is being held only by a tape. Inspect it and clean it. You might have to replace the condensers and/or switches on it.
This might solve the problem, but there may be other causes as well.
Aug 03, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
294 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
