Question about Acer Aspire 5315 Notebook
Safe mode computer is stuck in safe mode when trying to start device. What should I do to start the pc?
  • 2,794 Answers
Over ride it into normal mode.
Go into my computer. Select your hard drive with the mouse. Press the right mouse button and select properties. Select tools. Select scan disk. Press ok.
Restart you computer.
That should fix it.
Posted on Sep 11, 2008
How do I turn off safe mode my kindle fire
Safe mode means that problem has occurred when the tablet tried to "Boot" on. You must find and fix whatever that problem is to go out of safe mode.
Apr 08, 2017 | Tablets & eReaders
Toshiba satellite is stuck safe mode it's running Windows XP.I tried restart f8 start normal a black screen with bunch stuf& starts in safe mode. What's wrong how can I get it out of safe mode?
First you should really consider upgrading from Windows XP because it is no longer supported and the chances of your computer becoming infected are extremely high.
Pressing the F8 command will only access Windows RE where you can access startup repair safe mode etc.
If the computer is only allowing you to go into safe mode that is a good sign that something is severely wrong with your OS.
While in safe mode you should try and access system restore, but this will only work if 1) you have turned on system restore and 2) your system has a restore point to access.
Have you added any new hardware or programs to the computer? If yes, then the new addition may be the cause of this issue. You can use device manager to rollback any changes or access programs and features to delete any program changes.
Other then that, if none of the above suggestions work I would strongly suggest booting from the disk media to access Windows RE too recovery the computer or just to re-image the computer.
Hope that helps.
Nov 08, 2015 | Toshiba Computers & Internet
Why won't my sylvania netbook which runs WINDOWS CE..but it NEVER gets to the desktop page...what wrong?
I'm not familiar with Windows CE, but I have had similar problems with Windows 7 on laptops.
Try keeping the F8 key depressed when starting it up. The F8 key should allow you to start in 'safe mode'. I would imagine that the F8 'safe mode' is also to be found in Windows CE.
Keep pressing that F8 key as it powers up and hopefully it will present you with a screen that gives you a choice of 'safe mode' or network prompt. Choose 'safe mode'.
If your computer then starts in safe mode (it's just a minimum amount of drivers loaded to start the operating system) .. restart it again and see if it starts normally. You may have to 'play' and keep restarting it and pressing F8 ..
You can also change the boot up sequence as the computer starts. This is usually done by pressing the 'delete' key -or escape or f12 key (it varies from computer to computer)..
.. to take you to the bios settings. Change the boot order..if the dvd drive/usb is the first boot up device change it to hard drive as the first boot up device .. and see what happens.
It's almost as if the computer gets stuck in an endless cycle of 'trying to boot up' which is probably due to software conflict, for whatever reason.. some driver may not be loading to allow it to boot up correctly.
Jan 06, 2015 | Sylvania G-Netbook
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Computer stuck on E screen
Start in safe mode. Restart computer and continue pressing F8 during startup until the safe mode start up screen appears.
May 28, 2012 | Computers & Internet
When I boot up it is stuck in power save mode
Here are some information about the issue.
Here are the diagnostic lights that can help you identify the problem, click on the link.
For power save mode mostly it refers to video issue.  Try if you can go to safe mode, here are the steps to bot to safe mode. Make sure that the computer is turned off, turn it on, then hit F8 once you see the Dell logo, then black screen with option will appear, choose safe mode.  Then if it boots up to safe mode, here are the steps to troubleshoot the issue, open msconfig byt clicking on start then run then type msconfig, then go to boot.ini then put a check on base video, do not restart the computer yet, then go to device manager by right click on my computer then choose properties, then hardware then device manager.  Try to uninstall the video driver.  Then try to restart the computer.  Once in windows, connect to the internet go to support.dell.com, then download the video driver, depending on the video card that you are using.  Then go to msconfig again, and uncheck the base video.  If after doing this still the same problem, you can try to reseat the video card if your not using integrated video card. If the problem persist contact Dell Support.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 10, 2011 | Dell Dimension 2400 PC Desktop
Iam stuck in safe mode
In safe mode go into the accessories folder thru the start menu and then into the system tools folder. Choose System restore. Choose the last known working date that the computer was behaving properly.
Let the system reboot, if it still won't to into safe mode then save anything important that you want onto the hard drive and at that point you'll need to reinstall the Operating system, device drivers and any software that you need on the computer.
Apr 22, 2010 | Dell Inspiron 530 Desktop Computer
Cannot start up laptop; may be a virus
Try starting your computer in safe mode and do a virus scan once in safe mode. While in safe mode Windows only loads the basic devices to run your computer and usually viruses are not loaded untill windows starts in regular mode. Don't panic once you are in safe mode and your screen looks all grainy, this is normal.
  1. Restart your computer and press F8 as soon as you turn it on.
  2. Click the "safe mode with networking" option
  3. Update your antivirus
  4. Do a full system scan
  5. Restart your computer and hope for the best.
Jan 05, 2009 | Balance CN6555 Notebook
My laptop keeps closing down and saying my device driver is stuck in a loop
start your computer on safe mode by pressing the F8 key ,
after the booting, go to the device manager uninstall the driver, then start your laptop on normal mode install the updated driver get it through the site of the laptop company's website
Sep 29, 2008 | Computers & Internet
My pc starting problem
You can try starting win98 in safe mode, keep shift key pressed on startup to force safe mode. Then, If you can start in safe mode you may try to troubleshoot the problem uninstalling software recently installed, looking for devices that are not working properly in device menager, and eventually performing a virus scan and a system check using Norton utilities or a similar program. If the PC doesnt even start in safe mode I suggest re-installing the system from Win98 CD.
Hope this may help
Feb 14, 2008 | Microsoft Windows 98 for PC
Acer Aspire 5315 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
