Question about Microwave Ovens
How do i remove the microwave oven off the wall
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
Hello I am trying to remove my microve from the wall I did remove 2 bolts on top,I am non able pull
the unit out.anybody can give me suggestion. dave
Posted on Oct 28, 2008
Can you remove the microwave separately without removing the complete oven/microwave unit? KEMS307DWH4 KitchenAid Wall Oven/Microwave combo unit
Hello Richard;
My name is Peter. I am a retired field service technician.
Your microwave is in a separate housing than your oven. You need to remove the border stripping holding the micro wave in the wall, then lift up in the front and pull out.
Go into the following website, put in your model number which is on a label after you open the microwave door.
You did not tell me what the problem is. Please advise so I can help you further.
Mar 26, 2016 | Microwave Ovens
How do I remove my Sharp R 1870 from the wall
PUSH UR MICROWAVE VERTICAL. IT WILL DISMOUNT ON ITS OWN.. THEN U CAN UNBOLT THE FITTINGS FRM UR WALL..
Aug 24, 2012 | Sharp R-1870 Convection/Microwave Oven
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    How do i get it off the wall?? Thanks
    Have two people to assist in this operation.
    Remove the two screw bolts and washers [(3) & (6) in diagram] that secure the top of the microwave to the cabinet above.
    Remove the tap screws that hold the release levers in place from the bottom rear of the microwave (see (5) in the first photo below.
    **** CAUTION **** this step completely releases the microwave so have someone ready to support it's weight.
    Release the microwave from the mounting plate that secures the microwave to the wall by pulling down the levers (see second picture) that is on the bottom of the oven. Rotate that side of the oven out slightly, then release the lever that is on the opposite side and move that side of the microwave away from the wall. 1be92a7.jpge2fad72.jpg
    Oct 21, 2010 | Sharp R-1500 Microwave Oven
    How to remove the unit from the wall?
    there is 2-3 screws in the top of of your microwave that go the cabinet and it should have a bracket on the wall that the microwave should hinge off the wall from
    Feb 04, 2010 | Whirlpool MH6150XM Microwave Oven
    Remove a whirlpool over the range microwave oven
    Jim here. In cabinet above microwave, locate 2 mounting bolts.
    Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
    Procedure:
    1. Unplug microwave.
    2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
    3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
    4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
    5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
    6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
    7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
    Sep 30, 2009 | Maytag MMV4205 Microwave Oven
    How to remove from wall for remodel project
    There are 4 bolts or should be 4 holding the microwave top to the cabinet. Open the doors to the upper cabinets and you should see the bolt heads unplug the microwave unscrew the bolts while holding the microwave. After the bolts are out tilt microwave towards you and pick up from the bottom next to the wall to remove oven from mounting plate and thats it.
    Sep 16, 2009 | Sharp R-1505 Microwave Oven
    How to remove an old amana microwave from the wall model MVH-9T
    remove grease traps on underside. Look inside and remove
    clip(s) to wall
    Open cabinet above, remove two bolts holding microwave
    Slide out.
    Apr 27, 2009 | Amana MVH220E Microwave Oven
    How do I remove an old wall mounted Microwave.
    I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
    Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Removal of GE Spacemaker Microwave oven
    1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
    2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
    3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
    Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    222 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
