Question about Maytag Atlantis MAV9750A Top Load Washer
Water filling My water pulsates as the machine fills. I can almost eliminate the problem by setting the water temp. to anything other than warm/warm. It pulsates enough to cause the supply hot water pipe supply to hammer. I suspect that the water control valve it the cause but want another opinion before I buy parts and get into the machine to change it. Thanks to anyone who can help.
  • Anonymous Mar 14, 2014
    Replaced valve and now only hot water fills the machine
    President:
  • 878 Answers
Before you replace the water valve itself, take the hot water hose off and inspect the screen at the valve inlet. There could be a lot of grit restricting it. If the screen is clear, than I would be in agreement with you that it is the valve itslef..hope this helps you.
Posted on Apr 26, 2006
  • Ron Marek
    Ron Marek Jun 06, 2006
    I don't know what was so poor about the solution to this problem, evidently this cat knows all the answers. Maybe he should sign up as an expert.
My F&P WA75T65GW1 will not fill to rinse after the wash water has been pumped out. If I manually fill it, it will continue the cycle. Are you able to help? Thank you
when you wash do you set the water temp to warm or hot? it may have a broken cold water valve and may be filling with just hot water when washing instead of both, so when it gets to the rinse it cant fill with cold water, if you set it to just cold water does it fill on the wash?
Jan 31, 2017 | Washing Machines
Whirlpool Ultimate care 2 washer doesnt fill on start or rinse or spray in spin all other functions fine whats wrong?
The water valve has a 'Hot' and 'Cold' side, make sure to test if the unit will fill at a different water temp. setting, as a Cold/Cold setting will paralyze the machine if the Cold side of the water valve has failed... Some newer machines have temperature sensors attached to the valve and will not fill if the sensor fails... Washing Machine Water Inlet Valve 285805
May 23, 2016 | Whirlpool Washing Machines
Hot water hose pulsates when washer is filling up in warm setting.
It's the pressure from the hot water supply to your machine, if you fill from hot water tap, turn tap down a little to reduce the water flow. Should be OK then
Mar 15, 2015 | Kenmore 500 Whirlpool Washer Timer...
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
GE super capacity heavy duty washing not filling w/hot water
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Jan 21, 2010 | Washing Machines
Displaying LE
Lg has a water pulsator which rotates while filling up with water. If pulsator is faulty, you will get this LE indication. Pulsator is found on bottom left hand side of unit when cover is removed. 2 clear water pipes are connected to it and there is a small plug in that has 2 wires. Remove plug in first then remove from the pipes.
Sep 21, 2009 | LG Washing Machines
Pulsating water in the hot water cycle
id be curious as to the age of this machine, because the newer models have what teh call adaptive water temp sensors that will optimize the water temp automatically.. your hot water may be "too hot" and your cold can be "too cold" and the valve corrects to a preset temp. this sounds like whats happening
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washer won't fill in rinse cycle
REPLACE YOUR WATER INLET VALVE(HOT,COLD WHERE HOSES ARE)IT'S NOT OPENING ALL THE WAY TO LET THE WATER FILL UP FAST,LET ME KNOW HOW YOU DO-MIKE
Oct 19, 2008 | Maytag Washing Machines
Washer does not fill with water
, did you try changing water temps switch to different settings, hot cold amd warm alll no good?? do you even hear a slight humm when trying to fill???, how about trying to put into spin cycle, does it do anything??? if you listen closly (put your ear to the timer knob assy)can oyu hear anything??? if not its quite oossible that you have a power issue, check your incoming power for 110 volts.
Mar 25, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Atlantis MAV9750A Top Load Washer Logo
209 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
