Was fine until camping trip. Extreme high humidity in tent caused screen to fog up and all funtions mentioned stopped working. Moisture indicator inside battery compartment still indicates no water damage. Tried opening game slot and bat compartment and dry it out with hair dryer. no luck.
Hi sir..
please read this details.. u will get some information how to solve.
thank u
sir
Clean it thoroughly and make sure there is not any short circuit at printed board bottom side, and try again.Replace also internal battery if necessary.
Once water enter inside the circuit...the total circuit board will be corrupt..so no use of using dryer in it...better u give it to sony service center to rectify ur pro..u alone mostly cant rectify is..so contact authorised service center and rectify it
Winter’s cold temperatures can certainly damage hard drives and electronic gadgets.if temperatures (below 30 degrees), allow them time to warm to room temperature before operating them.else it may create problem oly..
Their are Screws that align the back casing and are small philips head screws.
If you remove those screws you can open the back casing.
After opening the back casing you can see all the internal parts.
Get yourself a bottle of rubbing alcohol and a few Q-tips.
Wipe down every internal part and let sit 30-minutes.
Hair dry over again while case is open to insure all parts are dried completely.
Remove the battery and plug into wall charger to test.
Things should work after, and you can replace the screws and be on your way.
Use a special cleaner before let it dry
Emergency thermal blankets are insulated blankets that give protection in all-weather condition's. If you are going camping in your backyard then you don't need to get one, but if you are doing a proper camping trip and want to be well equipped, it's a sensible precaution to take one with you.
Make
sure you don't eat in your tent. Apart from making it dirty, it encourages bugs
to come in. Also use a groundsheet so you protect the bottom of your tent from
stone and water damage. Air your tent when you get back from a camping trip to
avoid mold.
how is the product you mentioned used and what is it's full name. Forgot to mention that volume or speakers are not working
