Question about HP Photosmart 3210 Printer
Ink Color Issues
My HP Photosmart 3210 Printer just recently started having print color issues. When I print a photo on regular copy paper it prints fine, but when I try and print the same photo onto photo paper, the color is really off. (pinkish orange color). I've tried other photo paper to see if my photo paper is bad...didn't fix it. I tried changing my settings to what the settings are for when it prints on the copy paper (i think i did this correctly)...but it didn't fix it. Any help would be great! I have two small children and no time to figure it out on my own! Thank you!
This would be a setting issue. If it is printing correctly on one type of paper but not another then the printer is not configured correctly. I would uninstall then reinstall the printer driver.
Good luck
FinerWorks.com
Print on Canvas
Posted on Sep 24, 2008
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Does not print red on regular copy paper Does print red on 4 x 6 photo paper
Check ur printer settings. Might be set to print on photo paper.change settings to normal paper. If all else fails. Uninstall and reinstal printer software.
Nov 01, 2011 | HP Photosmart 3210 Printer
The paper tray has always had issues. It prints only 10% of the time. The rest of the time it says tray is out of paper. (it isn't) We need to replace this printer or resolve the issue. The printer has...
How new is the printer? It may be time for a new printer. If it's under warranty, contact HP and they should be able to fix or replace it.
If you decide to replace it with another ink jet printer, make sure you get one with separate color cartridges.
Apr 22, 2011 | HP Photosmart 3210 Printer
HP photosmart C6280 when i printed photo on plain paper the color came out is original color., but if i using same setup and printed on photopaper , the color came out not true...pls help this...
The process is different for photos than for plain paper.
It is likely that one of your colors are not printing, probably one of your `light' colors. You can perform a `nozzle check' by using the menu on your printer. This shows you the colors that are printing, and whether they are printing correctly.
If you are using refilled ink, that could easily be the issue.
Try performing the printhead cleaning, again in the menu on your printer. If that does not work, try replacing the ink tank for the faulty color.
If none of this works, it is likely that the ink delivery system is cracked, a common problem in these models.
In this case, replace the printer.
Sep 20, 2010 | HP Photosmart C6280 Printer
My hp Photosmart 3210 won't print in color and it has all the color ink cartridges
Have you gone to "printers" and hit preferences and made sure your choices are correct? Yours may be stuck on "print in grayscale" using only the black cartridge. There are several pages to work with, and each needs to be "applied" and given a name which is easily seen in upper half of the pages. It likes it to be same name (i.e., my favorite or some such). I just had to go through this twice this week! I reinstalled the printer as it was not functioning properly. I find that I can set my all in one to quick prints, drafts, and so forth as there is plenty of ink on the settings in my printer. Saves ink like crazy. For photos I'd go normal or "photo" printing. Watch the "wet" ink, however, and put clean page between each page printed. Only takes a moment to dry. This is a great printer!
Aug 10, 2010 | HP Photosmart 3210 Printer
Color in printed pictures is terrible! All HP
try going into your printers properties and look for a print quality tab. One of the tabs will allow you to change your print style on pictures. Or the HP software that came with the printer should allow you to modify the print quality.
Jul 06, 2010 | HP Photosmart 3210 Printer
I have a MAC OS 10.4.11 and an HP Photosmart 3210 all in one. I use Iphoto and have been trying to print a 4 x 6 photo from Iphoto directly to printer. No matter what I try the photo tray does not engage...
I haven't been able to make it work from photo tray either but I do put photo paper in main tray and change settings in Iphoto accordingly and print pics that way.
Oct 02, 2009 | HP Photosmart 3210 Printer
Color from monitor to printer isn't the same.
Go to your printer properties and play around with the options you are given. You may find an option for paper quality: photo paper, print quality in which you can choose from the options from economical to best printing to photo printing. This may solve the highlights and shadows if your printer is set to print regular business copies.
Dec 31, 2008 | HP Photosmart C5180 All-In-One InkJet...
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
205 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
