Question about KLH R3100 Receiver
Klh reciever ok i put the fuses back in, now what should i do, or is it out of my hands? can i replace or fix it myself?
  • KLH Master
  • 19,396 Answers
You do not know what you have to replace. You test the component on board, starting from the amp, you need a multimeter and service manual schematic to do this.
After finding faulty component you will need to use solderer and thermal paste to replace it, and you need experience, or you end up damaging the board.
Ave you done anything like this before?
I am going offline now, if you have more queries I can answer tomorrow
thanks
Posted on Sep 11, 2008
I have a KLH subwoofer which is connected to my reciever and speakers with speaker wire. It is not connected to an outlet. It has recently started making a buzzing/rattling type sound. Do I need to take...
Yes, probably, if you aren't capable of repair yourself. However, IMHO, a replacement will probably cost less in the long run. I have a KLH passive subwoofer myself. I wouldn't pay for any repair if it failed. Replacements are far too inexpensive.
Aug 18, 2014 | KLH Audio Players & Recorders
How to connect a subwoofer to a klh 5100
this unit has a sub output on the back to connect to a powered sub, or an amp/reciever and passive sub
Mar 09, 2013 | KLH R5100 Receiver
KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Jan 31, 2010 | KLH ASW10-120 Subwoofer
My Subwooofer only works intermittently when I move the gain dial. When left in any position it doesn't put out any audio. Sometimes I can push the dial to the right and get it to work when I hold it...
Try using "Tuner wash" if your lucky it's just a bad volume antenuator. It can be found at any electronics parts store. ie. Radio Shack. Pull the knob off, put a rag around any area that you do not want to spray, then spray the control. Let it sit for a couple, work the control back and forth then spray again. Let it set for a few then test. If that does not work you can replace the knob relatively inexpensively at Radio Shack as well. Hope this helps
Dec 16, 2009 | KLH ASW10-100 Subwoofer
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement?...
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
Nov 17, 2009 | KLH KL2400 Tuner
First of all a resistor color coding of Yel-Vio-Yel is 470Kohms not 470ohms. You are probably reading some stray voltage in the circuit. Yes, both NEG terminals of the speakers are common. Usually a receiver that blows the main fuse has a power suplpy problem. Check the recifier diodes for shorts. Other than that, the output transistors may be shorted.
Check those out and post the results.
Dan
Nov 17, 2009 | KLH Audio Players & Recorders
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
KLH R7000 Component Video Problems
I have lost my remote and instruction book where? do is it worth it replace
Mar 07, 2008 | KLH R7000 Receiver
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Sep 12, 2007 | KLH SE-6000 System
KLH R3100 Receiver Logo
93 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
