Question about Jensen VM9510 Car DVD Player
Jensen double din dvd monitor uv8020
Trying to bypass the parking brake to watch movies while im drivin
  • 1,586 Answers
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Posted on Sep 13, 2008
How to bypass jensen
There is a wire which grounds to your parking barke mechanism from your system. You must move this to another (fill time) ground.
Jul 15, 2014 | Jensen Car Audio & Video
Cant play dvd says parking brake on screen
you can not play dvd's when the car is not in park with the e brake on. I"m assuming it was factory installed or by a dealership??? they hook a line from it to your brake sensor. it's illegal to watch movies while you're driving. so long as theyre behind your seat and out of your view theyre legal, otherwise they hook it to your brakes.
Aug 14, 2012 | JVC Kwav60bt 6.1" Dvd Cd Mp3 Double Din...
When I try to play a movie, I only see the warning sign on the screen. I can hear the movie playing, but the warning will not go away. This is even when the vehicle is in park. Any ideas what may be wrong?
Bypass Code
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
Aug 18, 2009 | Jensen's VM9312 Car DVD Player
Dvd player wont show picture
To fix this issue on the back of the double din touch screen#uv8020, splice the pink wire, and splice into the (black) ground wire connecting them together. This will enable you to watch dvd;s whie driving.
Jan 22, 2009 | Phase Linear UDV9010 Car DVD Player
DDX512 Video Playback Bypass
I grounded my Jensen to a screw inside the dash. I had to put a switch on it though - Jensen requires an on-off-on sequence with the parking brake, which applies and removes the ground. I duplicate this by throwing the switch. Check the manual or online references to see if you have to do this. If you do, you'll need a switch. If not, you can just ground the wire.
Aug 19, 2008 | Kenwood Excelon DDX-7015 Double Din Car...
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Linear uv7
here's the code. I did this with my remote and it works.
press stop twice(which is also the band button)
press1,2,6,4
press down 1 time(button below the play/enter)
press play/enter 1 time
(you should see the menu now)
brake override should say no
I was told to change macrovision to no
hit system setup twice to save and exit
hope it works like mine did
Dec 07, 2007 | Phase Linear 160W AM/FM/CD Receiver W/...
Bypass brake for a jensen vm9311
the wire is pink and say parking on the wire.
Nov 24, 2007 | Panasonic CQ-C3300U CD Player
Jensen VM9510 Car DVD Player Logo
474 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
