Garmin nuvi 255W GPS Receiver Logo
Posted on Sep 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My garmin nuvi 255W does not start when I turn on the car
Anonymous
Level 2:
  • Expert 464 Answers
  • Posted on Sep 15, 2011
Anonymous
Expert
Level 2:
Answers
464
Questions
0
Helped
119330
Points
696
Does the nuvi power on without being connected to the vehicle power cable? If not, first place to look would be to check the vehicle power cable for power being supplied to the nuvi. The led indicator on the power cable that plugs into the vehicle port should be lit up. If it does not light up, the fuse may need to be replaced in the plug.
The power outlet on the vehicle should also be check to be sure that it is supplying power.
1helpful
I buy nuvi 255w ,what i have to do to update it
Garmin may give you one free update, depending how long you have had the unit. Check garmin.com for update policy
tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
tip
Garmin Nuvi 255W Favorites Backup and Restoration Procedure Models: Garmin...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin 255W WebUpdater here.
3helpful
Nuvi® 255W Car GPS Receiver: Can I get a owners manual for the Garmin nuvi 255W...
Hello.
You can find the garmin manual here.
Just type in your unit details.
tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Garmin Nuvi 255W Favorites Backup here.
tip
Download Nuvi 255W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
2helpful
2answers
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
