How to connect converter box fo older tv which does not have a coaxial cable connector to rabbit ears antenna
  • Anonymous Nov 02, 2008
    I can't figure out how to connect my convertor box to my tv and still be able to keep the vcr connected also.
  • 374 Answers
Okay if I don't know exactly what your situation is but it sounds as if your TV is not cable ready but instead has terminal screws for spade connectors to connect an Over The Air antenna. If this is the case thay mak a transformer that converts the signal from the coax attached at one end to that of spade connectors at the opposite end. If you do not have this set up but yellow/ white or red/yellow/ white inputs you could purchase an RF modulator and a set of composite cables to accomplish the same goal.
Hope this helps you and if you would please provide me with feedback on my solution by ranking it please. Thank you and if you need further assistance please post a comment to this solution.
Posted on Sep 11, 2008
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
I have a Magnovox video cassette & dvd player combo, model # DV200MW8. I have an RCA analog TV with 1 cable port in the back and 3 RCA jacks ports. Previously, my Maganavox VCR/DVD player was connected...
omg , haven't heard the word VCR in decade.
are you kidding? seems not.,
what's next 8track tapes? and Beatles? LOL ! "hard days night?"
omg 2, rabbit ears,, im blowing out a gasket laughing...
vhf/uhf analog tv is gone. now. (FCC rules ,dead) HDTV sure.
please say what you are up to the job.?
are you trying to burn VHS tape to DVD? nah.... that be me 16 years ago.... then gave all my VHS away at work. hated VHS, ugly mess.
i see, says the blind man!
you need a switch box.
yes, they still sell them like on ebay but not walfart.
Mar 13, 2017 | HP Compaq Presario V5204nr Notebook
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
