Question about Lexicon RT-20 DVD Player
LEXICON RT-20 REGION FREE CODE?
I have a Lexicon RT-20 DVD player that is Region 1 coded and can only play DVDs from the USA.
I am in Australia and unable to play any DVDs here because we are Region 4.
Would anyone know how to breek the code lock on the RT-20 so it is multiregion capable?
I kniw you can now buy these multiregion capable from Lexicon, so the player must somehow be able to be made multiregion capable also.
Thanks
Jon
  • Anonymous Sep 20, 2008
    Same Problem
  • jan2507 Oct 13, 2008
    I am in HK and unable to play any DVDs here because we are Region 3.
SOURCE: lexicon lambda
push the monitor button to go mono instead of stereo.
Posted on Nov 29, 2007
SOURCE: Lexicon Omega will not play any sound on Windows XP
Bye the way, I was having the same trouble but had not remembered to upload the Omega CD that came with the Lexicon.
Posted on Dec 27, 2008
  • 5603 Answers
SOURCE: Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Posted on Aug 24, 2009
SOURCE: Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Posted on Apr 08, 2010
  • 230 Answers
SOURCE: can you make mine region free
You guys may also like to check out something called Daniusoft dvd ripper which ever help me convert dvd to wmv, dvd to mpeg, dvd to mkv fast and losslessly
Posted on Aug 03, 2010
RCA blu ray/ dvd video player won't play regular dvd any longer
Laser assembly has lost the ability to focus and play back. Replace unit since repair not cost effective.
Dec 19, 2016 | RCA Televison & Video
Cant play dvd baught in england. player baught in the usa
There are different region codes for dvds and the player may only be able to play dvds with a north american region code.
Sep 08, 2009 | Radio Shack Accurian LMD-5108A Portable...
Can you make mine region free
Jul 28, 2009 | Lexicon RT-10 DVD Player
Hi i was after a no region code for a dvd player!!!
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
Hope it may help you;
Regards;
VOTIT
Jun 08, 2009 | Audio Players & Recorders
Unlock region code for JVC dvd player
if your dvd player is not region free it will not play us dvds it will only play burnt dvds and dvds from your region unless u buy a region free dvd player
there is no region free code for your dvd player
Apr 04, 2009 | JVC XV-E100SL DVD Player
Sansui DVP1210 dvd player- unclock code
REGION 6 -- China
Regards;
VOTIT
DONT FORGET TO RATE;
Jan 23, 2009 | Panasonic SC-HT520 System
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Feb 29, 2008 | Philips DVP3140
I would like to know this dvd player can play in europe
I couldn't find any info on this players region code, but most DVD stores carry DVDs from all regions, and many players today can play DVDs of any region. To be sure call the local DVD store that you like and ask them what region DVDs they have. Hope I helped ;]
Mar 30, 2006 | Pyle PLTV65R Car Video Player
Lexicon RT-20 DVD Player Logo
104 people viewed this question
Top Lexicon Televison & Video Experts
Electro Med Services...
Are you a Lexicon Televison and Video Expert? Answer questions, earn points and help others
