Question about Eclipse SW8102.4 Car Subwoofer
Finding the bad wire
How do I find out exzactly where the wire is fried?
    President:
  • 3,130 Answers
What wire??
Posted on Apr 25, 2006
Taotao atv ata-125d wiring diagram
well if your wires fried then your battery was around 20v which means your voltage regulator was bad. you need to purchase a new one of those as well. as for the wiring diagram, if the wires around the battery had been fried. are they intact or completely burnt without you being able to locate to which each wire connects to?
Aug 14, 2013 | ATVs
Im trying to find out why my punch p500-2 keeps going in protect mode?
Check for speaker wires that might of come off, Or a bad ground wire, If that is not the problem ,It is fried (Internally) End verry costly to have it (Repaired)
Nov 10, 2012 | Car Audio & Video
When i hook up through the loop on my marshall head, connecting cables are being fried.
If you are frying cables that is bad! This means you have a bad ground loop.
IF that is an old Marshall head that doesn't have a three wire (with ground pin) power cord on it, take it in immediately to have a three wire grounding cord on it before you fry yourself and not just cables. Their old technique of having a switch to change to create a pseudo ground was stupid and VERY dangerous !
You can severely damage equipment due to bad grounds.
ALWAYS connect all interconnected electronics to the same power source or receeptacle.
Mar 22, 2011 | TC Electronic G-Major 2
No electric power on a suzuki rf900. I have checked all the fuses. The battery is good and charged. The starter relay is working correctly. There is no electricity to the headlight or dash lights or...
a: Main 30A fuse blown - probably the wiring round the fairing bracket under Suzukis cable-tie
b: Main 30A fuse ok - the multi plug on top of the starter solenoid is corroded.
c: Very low battery volts - alternator coupling gone.
d: join www.rfownersclub.co.uk you will be rewarded with the best knowledge ever and all free
Feb 23, 2010 | 1997 Suzuki RF 900 RV
Box on top of battery keeps frying
some times overloading the small wires will do that ,check the amps and voltage,other wires may have a bad conection and the juice will go the shortest way,check the connections on the main ground and power wires,find the hotest spots where the problem resides as weak wire or a bad contact,you may want to double the hot ones to check
Aug 16, 2009 | 2003 Volkswagen Jetta TDI
Fried kill switch
kinda sounds like you might have pinched the wires putting the gas tank back on. check and hit me back.
Jun 06, 2009 | 1998 kawasaki ZX-9R Ninja
Alternator fried batts @ wires
It has got to be a bad short to ground some where from the regulator to the fuse box? Or the Alt. your useing is not the right one for the truck.
Feb 25, 2009 | 1984 Dodge Ram Wagon
My kenwood amp wont push my 10" rockford falsgate punch sun
It sounds like a bad ground, I would go through all your connections
Jan 07, 2009 | Alpine CDA-9885 CD Player
Amana electric LEA10AE dryer
usually that wire "fries off" with bad connection, ify ou can check for contionuty through the components on the heater you find the problemUsually the thermostat with the box like stand off mounted to that back wall.(also ck to make sure your breaker(s) didnt pop
Mar 09, 2008 | Dryers
Eclipse SW8102.4 Car Subwoofer Logo
37 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
