Question about Kodak EasyShare C330 Digital Camera
I dropped my camera and now the lens won't retract
I dropped my camera while the lens was out and it won't retract. The lens is very slightly off center now. When I turn the camera on it says lens error 12, then changes to 22. Any suggestions on what I can do to fix it? Should I take it somewhere to get repaired or is the cost to repair it not worth it?
  • 104 Answers
Get written estimate - should be free and then cost new camera -expect they will say about 2 mos to get repaired
Posted on Oct 31, 2008
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
The camera was dropped on the lens and zoom won't retract
HI there, the camera lens gear is damaged from internal. So you must changed that. Other wise it gives you lot of trouble. Thanks.
Mar 12, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
My casio EX-Z250 as been accidently dropped onto a soft floor from a small height this as caused the camera to disable itself and will not turn on but the lens as stayed out. I hope you can help....
Sounds like the lens could have been slightly tweaked, making it out of alignment just enough to not fully retract. You can try to GENTLY push it in the opposite direction to see if you can "reseat" it. If not, a service center is probably your best bet at this point...
Oct 21, 2009 | Casio Exilim Zoom EX-Z250 Digital Camera
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Still camera not working
See the sides of the retracting lens if there is something blocking it, a piece of dirt or sand... something like that.
If it doesn't work, then the unit needs to be checked by a camera technician.
Hope this gives you an Idea... Fixya me okay.
Feb 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Pentax Optio M20
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Jan 01, 2008 | Pentax Optio S Digital Camera
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Sep 30, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
My Sony Cybershot lens is not retracting!!
The lens block needs a replacement and you need a good service center for this job. We can help you in spares supply. Do let me know as this is an expensive spare part. Sonyspares
Jul 31, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
109 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
