Question about Panasonic CT-32HX41 32" TV
Won't turn on
Where are the fuses located on the Pansonic CT-32SX31 32" TV? CT-32HX41, bought in 2002.  Had it on and suddenly it turned off.  Can't turn it on, no click when pushing on button, no sounds, no red light.
Help?  Thx.
  • gizcosmo78 Nov 08, 2008
    After my tv is on a a few mintues it will shut off on its own. I will unplug and then plug back in. It will then work fine. Can it be fixed easily and cheaply?
    Novelist:
    Champion:
  • 203 Answers
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Posted on Sep 12, 2008
I have no sound coming from my panasonic. model # TH-46PZ80U i was fine then the next minute no sound while we were watching it
Posted on Sep 04, 2010
My pansonic tv model ct-13r37s won't turn on by
if their is no any power indicator at the front panel the cause is either the primary fuse at the power supply section blown. and then if the fuse is blown that was mean the regulator transistor and the horizontal out put transistor could also damaged. this case can be hand held by trained technician. if you want a do it with your own just make sure you have at least a basic knowledge in electronic repair since you are dealing with some high voltage parts a care must be needed.
Aug 12, 2012 | Televison & Video
Pansonic CT-32HXC14
This is a bad connection in the power supply, or a bad connection in the high voltage supply, and could also be expensive to repair if the regulator board is intermittent. I say if you can take it back, good riddance. Good Luck
Jul 27, 2007 | Panasonic CT-32HXC14 32" TV
My pansonic ct-13r37s won't turn on and I have no
Buy a universal remote and simply enter the right code which will come with the remote and your ready to go.
Looking for Part Number : KFT6AW45SF
There is no such FBT to Pansonic. Contact the nearest authorised service center for Panaonic at you town for details.
May 11, 2012 | Panasonic CT-32SL14 32" TV
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
Where is the fuse on a Panasonic CT-32HC43. It just won;t turn on. It was working great and then nothing.
The fuse is located on the power supply board. It looks like a small glass tube with metal caps at both ends like the ones in the image below on the board next to it you will see a small marking that says the specifications of the fuse. Ex: 10A(Read 10 Amperes), 120V. The replacement you are gonna purchase should be of the same specifications. Make sure you unplug the tv from the power supply before replacing it so that you will avoid the risk of electric shock.
A positive rating for the advice provided will be highly appreciated and I will be glad to assist you further if you need more help.
Sai.
Mar 29, 2010 | Panasonic CT-36HL43 36" TV
Won't turn on
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
Wont turn on
Hello zang,
This denotes a problem with the switching power supply or the high voltage power supply. what is happening is the safety relay is being actuated by the shutdown circuit. Any number of things can cause this proble but more then likely the problem is in the high voltage power supply section and or its associative circuitry. The switching power supply and the high voltages power supply have very dangerous voltages and I would not suggest that you work on the TV set unless you do have a background in electronics. If you do not I would suggest that you take the TV set to an electronics shop for repairs. If you do have a background in electronics, you will need the following items:
1) A schematic diagram (to know where voltage and signal test points are located and to have a reference of the levels.
2) A multimeter (to measure the DC voltage levels on the TV Set)
3) An oscilloscope (to measuer the AC voltage and signal levels in the TV set and compair them to the values in the schematic)
4) A signal generator (to generate a reference signal for troubleshooting)
I hope this helps,
Shuttle83
Oct 11, 2007 | Panasonic CT-32HX41 32" TV
CT-32HL42 Panasonic will not turn on
These sets have a number of problems like yours which are associated with bad solder connections or cold solder joints. On this set one pin on the the start-up relay is usually open or intermittent The solution is to resolder connections on main p.c board. and especially on the vertical output IC. Also change the caps in the vertical section to avoid future problems. Scrivitron.
Jul 06, 2007 | Panasonic CT-27G13 TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Panasonic CT-32HX41 32" TV Logo
285 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
