Question about Lexmark Office Equipment & Supplies
I am disabled and bought the Lexmark x6570 so I could send and receive faxes. I want to set the unit up on one phone line for use for both faxes and general phone conversation. I presently have a y connector that has one line going to my A.T.T. dsl router and the other to the phone which has a built in answering machine. What do I need to do to connect the printer so I can fax on the same line? Do I need to buy and adapter that three lines can go in? I can't afford a dedicated line for faxes because I am on social security. Please help me. I have used the printer and it was exceptional and I really like this printer. Thanks for any help you can give.
  • larreey1969 Sep 11, 2008
    Stevelxk I need to have a phone line into my dsl router also. I presently have a y splitter and I have one line going to the router and one to the phone. Your solution will work for the phone and the printer but I won't be connected to the internet without being connected to my router also. That is why I said should I buy connector with three slots and run one to the router one to the phone and one into the printer
  • 109 Answers
No, you don't need to buy an adapter, just one more phone cord. You already have the splitter, so run one phone cord from the splitter to the printer. You'll see there is a line in and out. Run the out to your phone. Voila. You should be all connected.
Steve
Posted on Sep 11, 2008
  • Steve Adams
    Steve Adams Sep 11, 2008
    I think you're still OK. The printer acts as another splitter. I'll attach a rough drawing of what I'm talking about. Good luck!!
    Steve
I have a Lexmark X6570 wireless and I want to send and receive faxes. How do you send a fax when you can't find the send button
Use the Check symbol instead. Here's the Lexmark 6500 Series User's Guide to give you a more detailed instructions on how to use the Fax feature for your X6570 printer.
Apr 19, 2011 | Lexmark X6570 InkJet Printer
I have a Lexmark x5650 all in one unit. I can send fax but not receive fax. What do I need to do
Make sure the correct phone line is connected to the printer and the correct fax number is set in the printer. This article in the Lexmark website will help you identify and resolve your fax problem: Fax Troubleshooting Topics
Apr 16, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Why can i not send a fax from my x6570 Lexmark printer
Are you able to receive faxes? This problem could be caused by several factors - e.g quality of signal, fax settings, etc. This article in the Lexmark website will help you determine and resolve your fax problem: Main Contributing Factors to a Fax Send Failure on an Inkjet All-In-One (AIO).
Apr 04, 2011 | Lexmark X6570 InkJet Printer
I have a lexmark x6570. I have att uverse phone/internet/tv. I have always been able to send/receive faxes. Now i can receive a fax, but cannot send one. When I do, the transmission report says...
Try dialing *82 and then the full fax # you are calling. AT&T sometimes has issues with caller ID functions, and I found that this caused me to be able to receive a fax, but not send one. Post back and advise whether this resolves your problem.
Best,
JudyP
Mar 26, 2011 | Lexmark X6570 InkJet Printer
Can send but not receive faxes
Is that a USB connected Lexmark unit?
Apr 24, 2017 | Lexmark X6570 InkJet Printer
Cant send faxes or recieve
Do you still have the problem?
Did you go through the entire setup procedure according to the manual including the fax/tel set up? Fax/tel setup tells the fax machine how you are using it. For example is the phone line used for just receiving faxes or is it used to receive phone calls AND receive incoming faxes OR is there a telephone answering device (TAD) attached to your phone line. If there is one, set it to 2 rigns. If you have it set to 4 rings the fax could disconnect before receiving the incoming fax. If you cannot send, then it has to be a line problem assuming you went through all the set up procedures correctly. Short of this you may have a bad unit and need to return it.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
X6570 fax
Open the document feeder and clean the scanner glass.
Jan 16, 2009 | Lexmark Multifunction Wireless Printer/...
Not receiving fax on my Lexmark X6570 coming from a computer
on a lexmark if someone send you a fax ,first the machine has to be in fax mode ,then when the phone start ringing you have to press the start button or #9 button
Oct 03, 2008 | Office Equipment & Supplies
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
