Question about Samsung Televison & Video
HOW TO CONNECT HDMI DVD TO PS50Q97HD - Samsung Televison & Video
  • 374 Answers
With the power to both devices off, plug one end of HDMI into the DVD player output and the other to one of the two HDMI ports on the back of the TV or the port on the side. Power the TV on first then the DVD player. Now you will need to use the input button on the remote to find the correct HDMI port you plugged into on the set. When you find the correct input the screen displayed will have the screen that is displayed when there is no dvd in the player- that is unless you have one in at the time.
Hope this helps you out.
Posted on Sep 11, 2008
How do I connect my view sonic 12843 to my DVD player?
Best option is to use the HDMI connector to connect the DVD player (assuming your DVD player has an HDMI port). Then make sure the monitor is set to accept the input from the HDMI port.
Feb 22, 2015 | ViewSonic Computers & Internet
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
How do i connect my laptop to my dvd player using hdmi cable
The HDMI connector at your laptop is output. The HDMI connector at the DVD player is an output also. So it's out of the question to connect two outputs, you may want to use the HDMI output from the dvd player to be connected at a tv or screen with HDMI input.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 12, 2011 | Toshiba Computers & Internet
I'm trying to hook up my dvd player to tv and don't know where the cables on the back of the dvd player should be????
RCA cables:
connect yellow on DVD to yellow on TV. Connect white (next to yellow) on DVD to white on TV.
OR if you have HDMI cable, connect HDMI on DVD to HDMI on TV.
Insert DVD, press PLAY.
Select proper TV input using TV remote. Cycle thru (Select input or Video etc.)
Mar 04, 2011 | Televison & Video
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Hdmi switcher
First check individually if they work ,then connect to HDMI switch ,then change the position of the switch if it is a manual switch or connect the cable to the dish and check the dvd works...............
May 29, 2008 | Toshiba HD-A2 HD-DVD
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
AVR 1508 Reciever Setup Issue
AVR 1508 doesn't upconvert. Only components coming in on HDMI will go out HDMI.
Nov 28, 2007 | Audio Players & Recorders
Televison & Video Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
