Question about Addtron AE 200 Network Adapter
Addtron AE-200 network card - jumpers setting
I'm looking for a manual in which I could find information about jumpers setting (e.g. how can I select the value of IRQ to 10 ?, etc.). Thanks!
    Champion:
  • 277 Answers
Hi check this out: http://groups.google.com/groups/search?hl=iw&q=Addtron+AE+200+jumper++settings&qt_s=%D7%97%D7%99%D7%A4%D7%95%D7%A9 good luck
Posted on Apr 27, 2006
SOURCE:
What are the switch settings on an old ISA (8-bit) multifunction 1200 Practical Peripherals card?
on the modem has a set of number with manuf. with it go theen to web site of card support download them there
May 01, 2014 | Computers & Internet
Need driver for Addtron AEF-330TX-1
Hello this is the only driver site i can find:
http://list.driverguide.com/list/company34/index.html
You maybe have to login as a user to download the file.
Or you can buy a new addin card that supports your
windows system.
Make sure the driver is to find.
Good luck
Oct 25, 2012 | Addtron AEF 330TX (AEF-330TX-20P) Network...
Where i can find information of the hardware
http://www.epinions.com/specs/pr-Addtron_Workgroup_Switch_ADS-1008I_Networking_Switch
here is a site that shows some specs
Retrevo.com will have the user information on some Ethernet switches> free acct
Sep 07, 2011 | Addtron Workgroup 8-Port Ethernet Switch...
I have an Intel D845GVSR motherboard. The 4 back USB ports are enabled but the two front ports aren't. I also have a Creative Combo NS DVD ROM with card readers in it. My Computer guy enabled the card...
This is probably set in the BIOS. You need to reboot the computer and enter the Setup/BIOS to enable the ports. Otherwise they're physically disconnected in the case and you will need and expert to reconnect.
Mar 07, 2011 | Intel D845GVSR Motherboard
I am looking for drivers for my Addtron AWP-100 PCMCIA Wireless
Good day Sir, try the link below and hope it will help to your problem.
Driver
thank you.
May 14, 2010 | Addtron AWP 100 Wireless Adapter
Go to the link below:
http://members.driverguide.com/driver/detail.php?driverid=131685
Mar 23, 2010 | Addtron AWP 100 Wireless Adapter
I had an idea to use a working addtron 16 port hub as a cheap and simple way to allow our boys access to the net and have control of their time online as well :>) We have a verizon account with an...
You do what you are describing, attach the hub to the router in any regular lan port. Then just plug everything you need to into the hub. Make sure dhcp is on on the router (it probably is) and just set it to automatically obtain the IP on the computers attached. The router can go through the hub (or switch) to give them IPs.
Aug 12, 2009 | Addtron (ADH-0016) Networking Hub
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
Addtron AEF-1004 network hub faulty?
Hey Beastman,
You have a real beast screwing around in that hub. You have choises:
1. Call the animal control department :)
2. Shoot it with a 22 :):)
3. Get another one.
A Hub acting like that has got its marbles juggled. Switching it on and off is the only way of flashing, and if that doesn't work, its jinxed. If you network it, you could spend a lot of time fixing network problems.
Hubs are cheap and not worth the headache.
Good luck.
Feb 21, 2008 | Addtron (AEF-1004) Networking Hub
Problems with Addtron AES820TX Hub
Is there any change in the configuration made, like is ICMP blocked. If youa re bale to pass traffic without any issues and if the issue is just that you are not able to ping the HUB there is a posibility of blocking the ICMP requests.
Dec 27, 2006 | Addtron Workgroup Networking Hub
Addtron AE 200 Network Adapter Logo
135 people viewed this question
Top Addtron Computers & Internet Experts
Alun Cox
k24674
Are you an Addtron Computer and Internet Expert? Answer questions, earn points and help others
