Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
NO Clean Dishes
I have a Kenmore elite dishwasher I purchased last December 2007. This is the worst dishwasher out of the five diswashers I have owned. It does not clean dishes. Its getting worse, glasses are becoming filmy, food lays in bottom of dishwasher. Food stuck on dishes. I have done the recommened things in the troubleshooting, by having my husband turn up the water pressure, turn up the water heat and nothing works.
  • icp2006 Sep 11, 2008
    I AM AT WORK AND WILL RETRIEVE INFORMATION FOR TOMMORROW.
  • icp2006 Sep 12, 2008
    The model of my dishwasher is 665 13122k701.
    Genius:
  • 1,239 Answers
Dear sir this may be the problem  Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Caution: Because the dishwasher is connected to both the plumbing system and the electrical system, you must consider both systems when working on this appliance. Before doing any work on the dishwasher, make sure the unit is unplugged or the power to the unit is turned off, and remove the fuse or trip the circuit breaker that controls the circuit at the main entrance panel or at a separate panel. Shut off the water supply to the dishwasher at the shutoff in the basement or crawl space under the kitchen.NO Clean Dishes - how-to-repair-a-dishwasher-1.jpg
thanks..................................
Posted on Sep 11, 2008
    Master:
  • 497 Answers
It could be a jammed soap dispensor. unscrew the front washer door remove the dispensor and clean out the old soap.
Thanks for using Fixya
    President:
  • 1,952 Answers
The Kenmore Elite has three washing arms. One on the bottom sprays water up. The middle arm sprays water up and down and the one on top sprays water down.
Clean Front" feature means that the controls (touchpad type) are on top of the door, rather than on the front. I'll admit this $100 extra was a bit of vanity, but it does make the dishwasher look more modern and makes the front easier to keep clean.
  • mohammed marika thambi
    mohammed marika thambi Sep 12, 2008
    It depends.
    If you use the dishwasher at least twice a week, you don't need to
    clean the inside. Otherwise, if it begins to get moldy inside--or if
    the residual water at the bottom of the dishwasher smells bad--put
    detergent in the soap dish and run the dishwasher empty, through a
    complete cycle.
    Most
    dishwashers handle the normal food residue left on dishes after eating,
    if you first scrape the dishes to remove any larger bits of food. But
    if anything is burned, melted, or stuck to the dishes, rinse and scrape
    them well, before you put them into the dishwasher. Leaving some
    residue is actually best, because the protein in the food reacts with
    the soap for more-effective cleaning.
    It may be a
    model that pre-heats the water. If so, and if the water entering the
    dishwasher is cool, the heater may take up to half an hour to heat the
    water.
    To avoid the wait, increase the incoming water
    temperature before turning on the dishwasher. Do that by running the
    kitchen sink faucet until the water runs hot. Or increase the
    temperature of the hot water to the entire house at the hot water
    heater.
    Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
    Brigadier General:
  • 3,614 Answers
May i know the exact model
  • micromaster
    micromaster Sep 11, 2008
    when you get back home, just try to inspect or check one of the ff:
    Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
    • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
    • Some
      have filters in the bottom of the dishwasher that you need to
      periodically clean. You don't need any tools to remove the filter, and
      cleaning it is easy. Consult your owner's manual to determine which
      type you have and its maintenance requirements.
    If your filter is clogged, it may be causing the cleaning problem.
    Drain valve
    Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
    Spray arms
    There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
    If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
    Detergent cups
    Dishwashers
    don't perform their best if detergent is introduced only at the
    beginning of a cycle, so add detergent to both parts of the cup.
    If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
    Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
    CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
    Hope this initial info, will help you on solving the problem.
    Any further assistance, just let us know more here.
    THANK YOU FOR USING FIXYA.
    REGARDS,
    MICROMASTER
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Dishwasher is not washing dishes.
Make sure your water is at least 120 degrees and change to a dishwasher detergent with a water softener and a rinse aid in it.
Jan 31, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Dishwasher
the problem is hard water. go to www.dishwahserfilter.com and get the difi filtration system.
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Oct 09, 2008 | Dishwashers
Smells bad
I have a very bad smell in my elite kenmore diswasher. We have had it for a year now. I have been smelling this now for several weeks and I didn't know where the smell was coming from until this morning when I pulled the door down to unload my dishes.
Jul 14, 2008 | Hotpoint 24 in. HDA3700G Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
204 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
