Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
POWER OUT DOOR LOCKED
My power is out and I have wet clothes in the washer. How do you unlock the door to get them out?
  • pwrvision Mar 03, 2009
    Have the same problem but the door is opened and the lock is engaged so I can not shut the door. I have taken the bottom panel off and pull the mechanism that you are referring to and it still will not unlock or "flip" the latch up (open).
    President:
  • 1,314 Answers
If you pull the bottom panel off and reach up the side where the lock is you will feel a tear shaped tab at the bottom of the door lock pull it down to un lock
Posted on Sep 11, 2008
Loaded washer with clothes, closed door. Press start and nothing happens. No display and door doesn't lock
better it has dry clothes than wet soppy ones if it has to fail . check your main circuit breaker for power
Jul 17, 2015 | Kenmore HE2 Plus Front Load Washer
Can I get my clothes out of my Kenmore Front Load Washer with no electricity?
I dont believe you can. When its locked its locked and with no power it will not be unlocked untill power comes back on.
Jun 30, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Display read suds, cloths wet and waher will not spin.
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
